» Sponsors
» Sponsors
Old 07-02-09, 11:07 PM   #1 (permalink)
attitudereflectleadership
the gold version's Avatar
Car 1: 1995 acura legend
Car 2: 99 camaro SS 6 speed
tdc on HB
on the HB wich markings is for top dead center on piston #1? there is three markings close to each other and two other markings way seperated ................HELP
the gold version is offline
Old 07-02-09, 11:24 PM   #2 (permalink)
Quaraxkad's Avatar
Car 1: 94 Legend LS sedan
Car 2: 92 Cutlass Supreme S
The one that is by itself is TDC. The other three are for measuring timing with a timing light, ignore those.
Quaraxkad is offline
Old 07-02-09, 11:39 PM   #3 (permalink)
but there is two marks by them selfs, how do i know wich one???????
Old 07-03-09, 12:10 AM   #4 (permalink)
Quaraxkad's Avatar
There should only be a total of 4, are you sure there is actually 5th?
Old 07-03-09, 01:00 AM   #5 (permalink)
yeah i double checked , and there is the 3 in a row then two others , but i lined one up to the middle tooth of the cover and i looked in the #1 cylinder and i can see the pistion, then i lined it up with the other mark and i cant see nothing but water , so i should be good right?
Old 07-03-09, 02:01 AM   #6 (permalink)
Quaraxkad's Avatar
That depends... Why are you setting TDC? If you are not removing the timing belt it's probably not that important that you get exact TDC.
There are other methods to try also. You can use the camshaft pulley timing marks, assuming your timing is set correctly you should be able to tell which mark on the crank pulley is correct. You don't have to remove the timing belt covers, you can pull out the rubber plugs and look straight through them. You can also remove the crankshaft pully, remove the lower timing belt cover, and look at the arrow on the timing belt drive pulley. Another more unreliable method is installing a compression gauge into the #1 spark plug position, turn the crank pulley until the first sign of compression drop.
Can you get a picture of those timing marks? I'm thinking one is just a scratch or something.
Old 07-04-09, 01:37 PM   #7 (permalink)
im doing the head gaskets,so i need that #1 piston tdc,that other mark is not a scratch it looks just like the other one . thanks for your help
Old 07-04-09, 03:36 PM   #8 (permalink)
Quaraxkad's Avatar
In that case, take off the upper timing belt covers, take off the the crank pulley, take off the lower timing belt covers, put the crank pulley back on, and use the timing mark on the timing belt pulley It's an arrow with a matching arrow on the block.
Old 07-04-09, 06:32 PM   #9 (permalink)
oh man more work..........guess i gotta do it . the legend is lucky i love it
Old 07-04-09, 09:46 PM   #10 (permalink)
Car 1: 91 Acura KA8
Car 2: BMW E39
Car 3: Mercedes W140
you can put a long stick inside spark plug hole #1... when u see it at it's highest point, line it up to a mark... only turn the crank clockwise tho... OR if you're car is properly timed already, like QuaraxKad said, take one of the upper timing belt covers off one of the cam sprockets, and see where it lines up... that should be TDC... check both cams for good measure...
javaco888 is offline
Old 07-05-09, 01:53 AM   #11 (permalink)
Quaraxkad's Avatar
The method I suggested isn't any more work than you'll have to do to remove the timing belt anyway. You have a lot more ahead of you, just be patient.
Old 07-05-09, 01:43 PM   #12 (permalink)
i tried putting a long extention in the #1 cylinder and i turned it and it didint seem to move at all. maybe i was doing it counter clockwise instead of clock wise ill try again but i think i have it tdc right now...
Old 07-05-09, 03:19 PM   #13 (permalink)
Quaraxkad's Avatar
You probably had it resting on the spark plug threads and not on the top of the piston. You can remove the crank pulley and all the timing belt covers, then just put the crank pulley bolt back in without the pulley and you can use the markers on the timing belt pulley and cam pulleys.
Old 07-07-09, 07:58 PM   #14 (permalink)
does the cam shaft (sprocket) have to be lined up before i can take the heads off? i have the driver side lined up but i cant get the passenger side to line up is there a trick to it?????????????????
Old 07-07-09, 11:40 PM   #15 (permalink)
Quaraxkad's Avatar
Did you already set TDC and remove the timing belt? Each camshaft should already be in the correct position when you set TDC on the crankshaft. Did you accidentaly spin a cam pulley after removing the belt? There's no reason you need to re-set each cam before removing the head once the timing belt is off.
