Originally Posted by the gold version
i cant seem to find a soft metal brush, ok so dont use the wire brush ...........those stains are stubborn as hell
i used a somewhat abrasive polishing pad that attached to my drill... not like sandpaper, but kinda like the back of a dish sponge... i didn't hold it it one spot for long... i don't think that it was abrasive enough to resurface the engine block, but you never know... and always kept it flat on the surface... it came with a couple different levels... i used the softest one... i got them at a local autoparts store...
kind of like this:
STANDARD ABRASIVE
METAL POLISHING from Aircraft Spruce
not sure if it was bad for it, but my car is running fine... and it cleaned it up pretty good...
EDIT: Here we go... this is what i used... the least abrasive one.... gotta have steady hand tho, to keep that drill from running off.....i didn't use them around the rings either.... just used a metal brush for around there...
SCOTCH-BRITE ROLOC TR SURFACE CONDITIONING DISC from Aircraft Spruce
those felt ones previously mentioned might work also... prob less abrasive then the ones i used...
+1 on what quaraxkad said about putting oil on those cylinder walls...
