Old 04-24-05, 06:48 PM   #1 (permalink)
Underground Legend's Avatar
Car 1: 91 Graphite Metallic
Send a message via Yahoo to Underground Legend
Tire wear questions
My rear tires tend to be wearing out on the edges.Drivers side on the outer and passenger side inner. They are cupping.The front tires are OK. Any ideas on how to fix this? Do I need new rear shocks? Thanks, J.J.
Underground Legend is offline
Old 04-24-05, 07:30 PM   #2 (permalink)
Car 1: KA8 1, 2, 3, 4, 5, 6, R
Send a message via AIM to KokDahkJeE
it's most likely your alignment
check its off
2nd Generation F.A.Q.
KokDahkJeE is offline
Old 04-24-05, 08:08 PM   #3 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
Inner is too much negative camber. Outer is too positive. Cupping is balance or worn shocks. Camber is also changed by amt. of load. Tell the elephant in the trunk to sit in the middle or he has to leave.
You don't typically find either side so far off unless a suspension part(s) is worn or damaged. Is the vehicle new to you? Could it have experienced a collision? If the rear was really hit, it could throw the specs off if it wasn't repaired properly. Or whoever performed the last alignment was a bona fide idiot and you ended up with camber settings way off.
A proper alignment will check condition of shocks, steering and also suspension parts. You should be able to see if the rear shocks are leaking and thus in need of replacement.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 04-26-05, 03:11 AM   #4 (permalink)
get tires balanced as that is primary cause of cupping unless shocks are gone, unlikely unless we are talking 300,000 mile Legend here.
Get car aligned at reputable shop and ask them to check the suspension components for wear. If you don't like what you hear, get a second opinion.
If the rims are other than standard acura, make sure they are seating properly. One fellow found that his center rings on after market (like hub cap) were keeping rims from sitting flush. Torque wheels and run tire pressure on nose. 32 front, 30 rear. If yo don't have a good 1% gauge, spend $45 and get one.
Best Wishes
Steve
Merlin the Wrench is offline
Old 04-26-05, 10:03 AM   #5 (permalink)
I have 154k miles on it, It is time for ALL new shocks,My passenger rear shock is no good.I will see if this corrects the problem. Thanks to all who replied
Uneven Tire Wear - Suspension? ahpleung Second Generation Legend (1991-1995) 8 12-17-04 09:06 PM
Dumb Tire Pressure Questions frantinez63 Second Generation Legend (1991-1995) 7 04-29-04 10:33 AM
Inner Tie Rods causing Tire wear (toe) ?? ZiggyB Second Generation Legend (1991-1995) 4 04-07-04 05:14 AM
Tire wear on stock suspension...... Silver Second Generation Legend (1991-1995) 6 03-03-03 01:41 AM
uneven tire wear? Acurate420 Second Generation Legend (1991-1995) 7 09-11-02 12:10 AM
