Transmission Filter Change Question - The Acura Legend & Acura RL Forum
Old 05-13-05, 12:11 PM   #1 (permalink)
Car 1: 1991 Acura Legend
Send a message via AIM to MyLegendnMe
Hey All,
I was recently having troubles with my 1991 Acura Legend, to which the car sounded as if the tranny was slipping. It was suggested that I change the internal strainer (transmission filter)...My question is this...If I recently changed my transmission fluid and I want to change the transmission filter, do I need to change the transmission fluid again?...If anyone can help, it would be greatly appreciated...Thanks...Peace
A Legend in My Own Right...
MyLegendnMe is offline   Reply With Quote
Old 05-13-05, 01:18 PM   #2 (permalink)
Car 1: 1992 Seden L Seattle Silver
Yes
Since you won't get all of the fluid out, I would add new genuine Honda fluid just to be safe. That way a higher percentage will be fresh fluid.
MikeTn is offline   Reply With Quote
Old 05-13-05, 04:23 PM   #3 (permalink)
Thanks MikeTN for the response, but what you you mean by "all the fluid?"...Im new to this procedure so please bare with me...Thanks
Old 05-14-05, 12:03 AM   #4 (permalink)
SBWooder's Avatar
Car 1: 1991 Frost White LS coupe
Car 2: 1995 Milano LS coupe
Send a message via AIM to SBWooder
After you replace the filter perform a flush, use the search and that will help you out; there have many postings on this procedure and topics and various ways to flush our trannys as well.
Chris ( Mr. Wood)
Frost on Ivory
SBWooder is offline   Reply With Quote
Old 05-14-05, 03:49 PM   #5 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
I posted your best friend:
DIY Transmission Service (Filter + Drain)
Old 05-16-05, 01:06 AM   #6 (permalink)
Buy a filter and 5 quarts of Honda ATF fluid. ALWAYS throw away the fluid that you drain from a car. NEVER reuse it. When you replace the strainer, I am pretty sure there is an O-ring you will need too. You'll see much more ATF drain from the car than a normal ATF change. Then add back 3 1/3 quarts when you are done. Start checking and keep adding until you get up to the mark. Start the car and let it run 10 to 15 seconds, HOLDING THE BRAKES and not moving, shift to neutral and then to drive. then to neutral, then to reverse then to park and turn it off. The order isn't critical. Then wait 3 or 4 minutes and check it again. The oil level may drop, if so, fill it to the mark again and then drive it to warm up the fluid. Then check it again while it is warm. Take your time on the transmission pan so you don't have any leaks. My year has two different gaskets depending upon the trans serial number. Be sure you have that just in case when you buy the parts. You'll need a flashlight to see it on the side of the trans with the hood open.
Best Wishes
Steve
Merlin the Wrench is offline   Reply With Quote
K&N Air Filter question Number13 Second Generation RL (2005 to Present) 16 05-27-05 01:03 PM
How easy is it to change fuel filter? Davincis '95 Second Generation Legend (1991-1995) 5 11-01-04 04:00 AM
replace transmission fluid filter? ndhduong Second Generation Legend (1991-1995) 1 07-29-04 08:23 PM
Transmission Oil Filter ashali13 Second Generation Legend (1991-1995) 3 07-02-04 11:49 AM
Cost of transmission fluid change for 5sp manual? mocca Second Generation Legend (1991-1995) 1 01-22-03 06:55 PM
