Transmission Fluid - The Acura Legend & Acura RL Forum
Old 02-15-05, 12:19 PM   #1 (permalink)
Car 1: 1992 burgundy Acura Legend L Sedean
Question Transmission Fluid
I misplaced my 92 legends manual. Which place should the transmission fluid be leveled on the Dip Stick for Safe and Normal operation of the transmission. Give all decriptions. Thanks :p
bobs92ack is offline   Reply With Quote
Old 02-15-05, 03:22 PM   #2 (permalink)
1......LOVE
Car 1: 1995 LS... white coupe
Send a message via AIM to MaSTeR.LeGenD
In the middle of the box. If its a drain and refill then use 3.5 quarts of Honda atf.
MaSTeR.LeGenD is offline   Reply With Quote
Old 02-15-05, 04:23 PM   #3 (permalink)
SBWooder's Avatar
Car 1: 1991 Frost White LS coupe
Car 2: 1995 Milano LS coupe
Send a message via AIM to SBWooder
ditto, any where in the middle of the box, but when the legend is at full operating tempreture and driven for a while, shut the legend off and it should be barely touching the top of the box. You get a better reading when the motor is off and warm for the tranny.
Chris
SBWooder is offline   Reply With Quote
Old 02-15-05, 11:34 PM   #4 (permalink)
What box, do you mean the engraved rectangle thing? Is this what the manual say? My fluid level goes all the way up to the wire past the dipper, and i have notices weird shifting, will i need to let some out?
Old 02-16-05, 02:57 AM   #5 (permalink)
1......LOVE
Yes Yes Yes
Way to much in there bad for tranny. Go to the drain plug for the tranny, Let it drain, put plug back on and fill 3.5 honda fluid only. Should sit in between the little engraved box on dip stick.
1Louie
Transmission Fluid questions for experts Andrew First Generation Legend (1986-1990) 3 08-24-04 03:31 AM
Transmission Fluid - Change it !! AlanJ First Generation Legend (1986-1990) 16 02-09-04 05:11 AM
PSF or transmission fluid leak?? what should i do??? unofficial Second Generation Legend (1991-1995) 1 12-03-03 01:56 PM
Why "ONLY HONDA ATF" ?? Tom Boerger Second Generation Legend (1991-1995) 10 09-18-03 05:30 AM
Cost of transmission fluid change for 5sp manual? mocca Second Generation Legend (1991-1995) 1 01-22-03 06:55 PM
