» Sponsors
» Sponsors
Old 11-06-08, 11:20 AM   #1 (permalink)
Car 1: 2005 Mini Cooper S
Car 2: 1991 Acura Legend LS
Car 3: 2001 911 TT
Tried to change brake pads, can't push piston back!! Seized or collapsed brake line
I was changing my rear brakes the other day and I changed the drivers side fine. WHen i went to do the passenger side, the piston would not budge no matter how hard i tried. I took the cap off the master cylinder, took out some HUGE 20" Channel locks and still couldn't get it to budge. I asked a friend who said it could be that the line is collapsed and won't allow the fluid to move back. I am thinking I just need a new caliper, but i'd hate to get a new caliper and have it be the lines!!! Any ideas?
D_Nyholm is offline
Old 11-06-08, 11:24 AM   #2 (permalink)
Blackend Motorsports
3 Wheel Slot Machine Champion
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
iTrader Score: 23 reviews
If you're using channel lock pliers, you've probably just bound the piston by only applying force to one side of it. The piston has to be pushed directly back into the caliper, any additional force on one side of it will cause it to bind up and not go back into the caliper. Try getting a big C-clamp and then using the plate from the old brake pad to push down directly over the piston.
Blackend is offline
Old 11-06-08, 11:28 AM   #3 (permalink)
Car 3: 2001 911 TT
I thought the same thing so I made sure they were pushing back perpendicular to the piston face. They are HUGE, pretty easy to make sure they push back straight. The other side was cake, didn't even have to push hard.
I'll give it a shot with a c-clamp and old pad to see if I can get it to go that way. If I really clamp it tight, can anything else break on it?? Or I would just need a new caliper anyway?
D_Nyholm is offline
Old 11-06-08, 11:32 AM   #4 (permalink)
Renaissance.
whats77inaname's Avatar
Car 1: 91 5MT LS, 310k
Car 2: 91 5MT LS, 208k
Car 3: 03 G35 sdn (wife's)
iTrader Score: 33 reviews
Just go to Autozone and get a brake caliper compressor tool. They're like $9.00, and easy to use, and you don't have to worry about uneven pressure on the piston.
whats77inaname is offline
Old 11-06-08, 11:39 AM   #5 (permalink)
what!
kotetu's Avatar
Car 1: 95 LS Coupe 6 spd
Car 2: 02 TT225 Quattro 6sp
Car 3: 94 L Cpe 6spd - sold
iTrader Score: 20 reviews
Autozone charged me $37 to borrow it but refunded me 100%.
kotetu is offline
Old 11-06-08, 11:42 AM   #6 (permalink)
Renaissance.
Really? I picked up my unit from them for $9.xx on the recommendation of a friend of mine who used to manage a brake shop. I'll see if I can find a pic.
Edit: Ah, here we go. It's called a "disc brake pad spreader". $9.99 @ JC Whitney.
Old 11-06-08, 02:02 PM   #7 (permalink)
has left.
antik's Avatar
Car 1: 98.5 BMW M3 Coupe 5MT
Car 2: 95 L Sedan
Car 3: 95 6MT Coupe (Dad's)
My "disc brake pad spreader" looks like this:
antik is offline
Old 11-06-08, 02:48 PM   #8 (permalink)
Lone Star Legends
BigRed's Avatar
Car 1: '93 Legend L-driver
Car 2: '97 Silverado-worker
Car 3: '08 Odyssey-wifey
I did mine with a 6" C-Clamp with absolutely no problem. Both sets of rear pads took me 15 minutes...the easiest brake job I've ever done.
Wes ...a Lone Star Legend OG!!!
'93 Legend L 5MT Sedan
sigpic by alexmphotography.com
BigRed is offline
Old 11-06-08, 03:05 PM   #9 (permalink)
Low mileage nutso
MarcD's Avatar
Car 1: 95 Legend LS coupe 6MT
Car 2: 94 Legend LS coupe
Car 3: 2005 GMC Yukon
If he can't get it back in with a large C Clamp, there is no way that 'official' tool is going to work. I have one of those and they work fine but no where near as powerful. You most definitely have a collapsed brake hose. I have had that happen in the past. Easy to change out. Did you notice your brakes pulling or dragging on you?
MarcD is offline
Old 11-06-08, 03:50 PM   #10 (permalink)
reboticon's Avatar
Car 2: 91 civic, 90 Integra
Car 3: 71T-bird, 95Explorer
iTrader Score: 6 reviews
Sooo... you guys know you are supposed to loosen the bleeder screw and then push back the piston, right?? Simply taking the cap off the master= big no no. Its ok to do on Pre-ABS cars, but improper procedure is the number 1 killer of ABS units..
My Low Buck Non-Legend Builds
90 DA Teg
89 Boosted CRX!
reboticon is offline
Old 11-06-08, 04:01 PM   #11 (permalink)
Renaissance.
Hmmmmmm, I dunno, man. I've never had an issue using that, and it has always been all the force I need. I wasn't suggesting it as a method to solve *his* particular problem, more like an addendum to Blackend's post about making sure that the piston is put back into place while exerting equal amounts of pressure across the piston.
Old 11-06-08, 04:32 PM   #12 (permalink)
sap
sap's Avatar
Car 1: 92 LS Sedan AT
Car 2: 93 L Coupe 6MT :(
Car 3: 86 Camaro IROC Z
Send a message via AIM to sap
Seriously? I could have used this a week ago before I changed my rear pads, don't know what made me think Haynes could be trusted
Haven't been greeted with an ABS light anyway.
sap is offline
Old 11-06-08, 05:19 PM   #13 (permalink)
Honda fanatic
3.2legend's Avatar
Car 1: 1994 black acura legend coupe
Loosen the bleeder screw to the brake caliper? You mean so that air wil get in the system and then you will have to bleed the system afterwords?
Sounds like a bunch of bullshit. Ive dont lots of brake jobs on abs cars to never have anything go wrong with them and i just took off the master cylinder cap so the fluid wouldnt spill out.
I would like an explanation for your logic on this.
Rebuilt by me ITR swap in 1900 lb cx hatch...not bad!
3.2legend is offline
Old 11-06-08, 05:22 PM   #14 (permalink)
Honda fanatic
3.2legend's Avatar
Hey man, do your caliper pistons have slots (grooves) in them? If they do, then your supposed to put somehting in there and turn them in instead of pressing them in.
Old 11-06-08, 05:44 PM   #15 (permalink)
daddykay24's Avatar
Car 1: 2002 3.5 rl and 92 legend
Car 2: 2005 lexus Ls430
Car 3: 2007 Cobalt SS
iTrader Score: 7 reviews
Our calipers are known to freeze up. So if none of the above ^ methods are working, just replace the caliper. I just had to do this myself because one was frozen, so I changed both of them.
daddykay24 is offline
