Turn Signals - The Acura Legend & Acura RL Forum
Old 11-14-12, 10:52 AM   #1 (permalink)
Car 1: 92 G2 4D 5spd...
Car 2: 99 Tahoe LS 4wd
Car 3: Trek Bike (Less Gas)
Question Turn Signals
I am installing custom turn signals in my mirrors and would like to know what wires control the LEFT & RIGHT signals.
NYTAHOE is offline   Reply With Quote
Old 11-18-12, 06:41 PM   #2 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
I tapped into the front bumper lights for mine.
Old 11-20-12, 06:51 PM   #3 (permalink)
Thanks for the advice. Did you have to remove the bumper, or just trace back to the wires? Does the lamp just contain a HOT & GROUND?
Old 11-20-12, 08:19 PM   #4 (permalink)
BIGBOY's Avatar
No need to remove the bumper. Since your car is stock just remove the light like you would to change a burnt out bulb. Than tap the wires.
Old 11-21-12, 11:45 PM   #5 (permalink)
Car 1: '92 Acura Legend LS
I'd love to see some pics of mirror signals. I've been thinking about adding them, so I'd appreciate some inspiration. Thanks!
Sent from my iPhone using AutoGuide.com App
My "free" 92 LS
Old 11-22-12, 09:06 PM   #6 (permalink)
Thank you BIGBOY... LowPSI once I am done, I will have some photos of the finished product. I got the idea and product from Ebay (the concept is huge in Asia). I ordered some CONCEALED SIGNALS that go behind the glass. It does require some work and a different mirror, as the OEM is not translucent. I will post all the details once I'm finished.
Old 11-23-12, 05:23 PM   #7 (permalink)
BIGBOY's Avatar
Your welcome man.
Old 11-24-12, 02:44 AM   #8 (permalink)
Is there any way to remove the silver on the mirror? Just thinking - really looking forward to seeing your pics!
My "free" 92 LS
Old 11-24-12, 12:47 PM   #9 (permalink)
No chance. After I took the OEM mirror apart, I did a test with a flashlight. I wasn't able to see the light through it and found that it had to be replaced. I needed to replace it due to it being cracked anyway, I found one on Ebay (made by BURCO). I found that this is the replacement glass that glass shops use. When I supply all the details I will give you the model numbers for both sides.
Old 11-24-12, 01:23 PM   #10 (permalink)
BIGBOY's Avatar
Actually a member from across the pond did use our normal mirror. The downside is you will lose heat at the spot where you separate the heat element from the mirror.
Old 11-26-12, 08:57 AM   #11 (permalink)
Bigboy you are correct, you do loose heat in that section. The only thing I did not like is that with the OEM mirror, you could hardly see the signal through it. It seems to be thicker than the aftermarket and doesn't transmit as well.
Old 11-26-12, 08:01 PM   #12 (permalink)
BIGBOY's Avatar
^Well you wouldn't want it being too bright anyway. It would prevent you from seeing what's behind/beside you. I can't wait to see what yours look like, I thought of doing some.
