FIXED HEAD GASKET, BUT Where do I mount the transmission vent aka "breather"?
Sup all,
I took apart my engine to fix my head gaskets. Now I have one part that needs to be mounted, but I do not know where to mount it. My uncle, who was the mechanic that fixed my car, assumes it is a transmission vent. The Acura dealership called it a breather. The dealership gave me this diagram. It is #2 located on the upper left of this diagram circled in red: ![]() Here is the circled red area zoomed in: ![]() if you want I can email you the larger detailed diagram -- cbihis@hotmail.com here is a pic of the actual breather: ![]() and here is where it is located in the engine: ![]() Also my check engine light comes on frequently and my "D4" (drive 4) light blinks repeatedly. Even when my "P" (park) light is on! Here is a pic: ![]() I am assuming that the reason my check engine light comes on frequently and my green "D4" (drive 4) light blinks repeatedly is because of the "breather" not being mounted. Please correct me if I am wrong and tell me where to mount the breather. One. Last edited by DonChiChino : 05-27-05 at 04:39 AM. |
That part mounts on the bracket that holds the trans dip stick tube to the valve cover. There are 2 open holes on that bracket. It mounts on one of them.The blinking d4 light has nothing to do with your HG replacement and the breather tube. It's a bad speed sensor at the transmission. Replace it. search for "blinking d4" in this forum and you'll see a lot of postings on that.
After reading your electrical problem again, i'm not sure. You need to check that all of your electrical connections are solid. Last edited by The_Iceman : 06-06-05 at 04:45 PM. |
| Transmission mount need to know | Merlin the Wrench | Second Generation Legend (1991-1995) | 2 | 04-15-05 12:16 PM |
| Should I sell?worth? Got quote: axles, transmission mount (sort of) and engine mount | 92Legendsedan | Second Generation Legend (1991-1995) | 1 | 03-26-05 12:52 AM |
| Rattling noise problem, rear transmission mount??? | mocca | Second Generation Legend (1991-1995) | 0 | 03-25-03 12:54 PM |
| Question for those who personally replaced transmission mount | Merlin the Wrench | Second Generation Legend (1991-1995) | 2 | 01-25-03 04:08 PM |
| How many guys here bidding on transmission mount? | dandadda | Second Generation Legend (1991-1995) | 2 | 10-11-02 09:20 AM |
