why was my radiator hose collapsed? - The Acura Legend & Acura RL Forum
Old 03-09-04, 12:42 AM   #1 (permalink)
Car 1: 1992 Green Sedan
Send a message via ICQ to thekitt
Question why was my radiator hose collapsed?
it was after i had driven my car about 20 miles...
then when i saw it collapsed...after my car cooled of course...i opened the radioator cap and the hose opened back up..
what would this mean?
http://us.f1.yahoofs.com/users/7ee08...cG4W.ACJ08XfES
Counting Down The Days
thekitt is offline   Reply With Quote
Old 03-09-04, 01:24 AM   #2 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
not enough pressure??
Old 03-09-04, 01:27 AM   #3 (permalink)
twg
Car 1: 1990 Acura Legend LS Sedan
you need a new radiator cap...
when there's low pressure it should suck coolant from the overflow reservoir. If it can't, that means the radiator cap is defective and preventing this from happening.
twg is offline   Reply With Quote
Old 03-09-04, 02:28 AM   #4 (permalink)
u mean to tell me that a radiator cap is all i need to fix the pressure?
please explain as i'm not such the car repair genius...
thanks
Old 03-09-04, 02:37 AM   #5 (permalink)
Uncle Stinky's Avatar
The radiator cap serves three purposes really:
1.Keeps cooling system from overpressurizing by blowing excess coolant into the overflow resevoir.
2.Keeps cooling system from becoming a vacuum, as in your situation, by drawing coolant in from the overflow resevoir.
3.Keeps coolant from flowing everywhere.. obviously.
Typically, the system is under pressure when it is hot, or at running temperature, and the pressure drops as the engine cools. Replace the cap.
Uncle Stinky is offline   Reply With Quote
Old 03-09-04, 03:07 AM   #6 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
I would also replace the hose now that it's been squeezed like that.
Old 03-09-04, 03:43 AM   #7 (permalink)
Type I King
Car 1: 92 LS Sedan
what psi is ur rad cap, sounds like its releasing too much pressure out of the system
Old 03-09-04, 04:55 PM   #8 (permalink)
(1) replace the cap witha Honda cap.
(2) if that fails to solve the issue, when the car is cold, pull the hose out of the bottle and run compressed air through the small hose between the radiator neck and catch bottle to make sure it isn't plugged.
(3) If the top hose seems soft, replace it.
Best Wishes
Steve
Merlin the Wrench is offline   Reply With Quote
Old 03-11-04, 02:16 AM   #9 (permalink)
FF Drifter's Avatar
Definitely replace the hose the collapsed. If you squeeze it and it makes crinkly noises, the bands inside the hose walls are no longer supporting it and the hose need replacment.
