» Sponsors
» Sponsors
Go Back   The Acura Legend & Acura RL Forum > Acura RL > First Generation RL (1996-2004) > Engine & Performance Modifications
Old 05-16-06, 09:19 PM   #31 (permalink)
Car 1: 96 Legend
Originally Posted by 91LegendCoupe
3g legend,
can u elaborate on this ?
is this happening because you cut the tops ?
does this mean the shock will rest on the fork properly if I don't cut the top ?
dont cut the tops of your forks like I did to get the car lower and the shock fits like stock.
3g Legend is offline
Old 05-16-06, 09:52 PM   #32 (permalink)
misdeismo's Avatar
Where do you hook up the brakelines? To the knuckle? I thought that the rl, like the legend connected to brackets on the oem shocks.
misdeismo is offline
Old 05-16-06, 11:11 PM   #33 (permalink)
Car 1: 96 Legend
use ty-wraps. no big deal. just make sure you dont let the lines go all over the place...mine never did.
Old 01-14-09, 05:33 AM   #34 (permalink)
i have a 99 RL will the tsx teins be a bolt on affair? i was looking at the SS, Basic, Flex and Premium spec driving master comfort specs...
pmendoza502 is offline
Old 01-14-09, 04:21 PM   #35 (permalink)
3.5RL's Avatar
Car 1: 1996 RL
how come none of the pictures isn't showing? only red X, can you post the pic up again. thank you.
BI-XENON RL! Hmmm yummy
3.5RL is offline
Old 05-25-09, 08:20 AM   #36 (permalink)
so after a bit more searching, i find that the g2 legends suspension will fit an RL also
so my what im wondering is has anyone tried a combination of say a tsx shock with a g2 spring on a ka9 RL?
If i were to piece the suspension together my self rather than get a full coil over kit such as the tsx ss/basic/flex, would you recommend tsx or g2 springs mated with tsx or g2 shocks?
im thinking of going with the eibach pro kit, and i might have even seen an RL specific pro kit but i need to double check. I still want comfort with just a lower ride and just a tad bit stiffer so that my 225/50/17s dont rub!
(im also planning to eventually go with 18s or maybe even 19s but keeping the same basic overall diameter ie- 215/40/18, 215/30/19)
what are your recommendations?!
thx!
Old 06-05-09, 08:29 PM   #37 (permalink)
Car 1: 1997 RL
Car 2: 1994 Vigor
Do you have a pre-2002 RL? I just put '02-'04 struts, coils, and rear sway bar on my '97 RL and the difference is very noticeable. Some how I doubt G2 or TSX coils are stiffer. Both are made for a lighter car. TSX coils would feel softer on an RL than they do on the TSX. If you want to go stiffer than '02-'04 RL coils, you will probably have to go with aftermarket coils. G2 Eibachs with G2 shocks would probably be pretty nice without breaking the bank.
Rower4VT is offline
Old 07-18-09, 01:49 AM   #38 (permalink)
i'll have to see if i can get my hands on a 02-04 stock suspension
Brakes 95sixspeed Engine & Performance Modifications 4 03-06-05 01:51 AM
Help! Brakes went out...then steering went out! 92Ruby Second Generation Legend (1991-1995) 6 08-02-04 02:20 PM
clicking from rear wheels legendcoupe93 Second Generation Legend (1991-1995) 1 03-20-04 12:21 AM
Brakes went out!! Broken Caliper LIVING_LEGEND Engine & Performance Modifications 10 06-16-02 08:58 PM
Help! How do I remove my rear wheels? T Radz Second Generation Legend (1991-1995) 8 05-07-02 01:39 PM
