Bad radio reception - The Acura Legend & Acura RL Forum
Old 04-02-08, 01:43 AM   #1 (permalink)
95LegendGS
Guest
Posts: n/a
Bad radio reception
Well I just put a new alpine unit in my car, but now the radio reception is worse then before. How can I get my FM signal to be strong in my GS?
Old 04-02-08, 01:51 AM   #2 (permalink)
SGM / Type F
samblaze's Avatar
iTrader Score: 11 reviews
Did you plug in both antenna cables or just one?
86 Saab 900S Coupe 5MT
94 Acura Legend GS 6MT
04 Subaru Forester XS 4EAT
Sig by Double Glow
samblaze is offline   Reply With Quote
Old 04-02-08, 01:53 AM   #3 (permalink)
RedLegend92's Avatar
Car 1: 1992 Acura Legend LS Sedan
Car 2: 05 Suzuki RMZ-250
Car 3: soon Suzuki GSX750
Send a message via AIM to RedLegend92
Huge antennas with foil balls at the end lol..jk R u sure that all your plugs are all in? Maybe the wire shorted out? Idk just some ideas. Good luck. Personally I would just unplug the antenna power and use an Ipod man. Thats what I did.
CHICAGO LEGENDS!
Custom CAI
magnaflow catback exhaust
2 12" kicker cvr12's with a 2253 watt (751 rms)rockford amp w/ Cap
Pioneer head unit w/ pioneer ipod adapter
Rial 16" rims w/ goodyear triple tread tires
3 gauge pillar w/ autometer cobalt gauges.oil pressure, water temp, and air/fuel
GTS Smoke headlight covers
Venom 400 performance chip
Clear Corners
Mod Express 6000k HID kit
Addco rear sway bar
Blackened Engine Damper
20% tint
RedLegend92 is offline   Reply With Quote
Old 04-02-08, 01:55 AM   #4 (permalink)
95LegendGS
Guest
Posts: n/a
Aftermarket headunits only take one antenna wire not both. I hate ipods like the plague so much that my headunit will NOT work with it no matter what
Old 04-02-08, 02:07 AM   #5 (permalink)
SGM / Type F
samblaze's Avatar
Which one did yours take? The power antenna only I'm assuming. Check the antenna itself for connections (ground resistance etc), but without the rear glass antenna boosting the signal your options are limited. Does your HU have FM sensitivity adjustment on it?
Some info here: Improve FM Reception
One of the amplifiers mentioned in that article might be an option for you.
Sig by Double Glow
Old 04-02-08, 11:25 PM   #6 (permalink)
mellofelow's Avatar
Car 1: 94 L coupe 6 spd
Car 2: Lex GS, Sienna, FZ6
iTrader Score: 14 reviews
I have the same experience changing to an aftermarket radio. Is it possible to Y the two antenna together into one?
mellofelow is offline   Reply With Quote
Old 04-10-08, 04:13 PM   #7 (permalink)
Car 1: 2005 Mini Cooper S
Car 2: 1991 Acura Legend LS
Car 3: 2001 911 TT
I too have terrible reception with my 91 LS sedan. I think it has to do with the antenna itself. I unbolted the motor unit and sanded down the grounds to the body and I also cleaned up the antenna mast with WD-40 and it got slightly better. I think I am going to try to replace the unit with a standard whip antenna and hope that fixes it. Has anyone else done that with success???
D_Nyholm is offline   Reply With Quote
Old 04-10-08, 04:52 PM   #8 (permalink)
Why did the chicken cross the road? Champion, Six Feet Under Champion
nino418's Avatar
Car 1: 1992 Acura Legend LS Coupe 5 speed MT 3.5 hybrid
Send a message via AIM to nino418
there are two antenas????? Thats why my reception sucks. How do you connect that second antenna to an aftermarket headunit?
nino418 is offline   Reply With Quote
Old 04-10-08, 04:56 PM   #9 (permalink)
Car 3: 2001 911 TT
The second antenna is in the back window. I am probably wrong, but i heard it was for the AM reception. I don't beleive there is any way to attach it to your aftermarket head unit. It is basically a smaller version of a standard plug.
Old 04-10-08, 05:03 PM   #10 (permalink)
nino418's Avatar
I was wondering what to do with that second antenna plug. I saw the back window and it reminded me of the 1998 Accord my mom had which and an antenna in the back window, but the Legend has a power antenna so i was like
Old 04-11-08, 12:05 AM   #11 (permalink)
makes his putts....
DevanTheDude's Avatar
Car 2: 1966 Mustang
Car 3: 06 GTI 2.0 turbo
Aftermarket radios generally get poorer reception. Alpine being the worst, Eclipse usually the best. When customers came into my shop looking for better am/fm reception, we would generally tell them to keep it stock.
DevanTheDude is offline   Reply With Quote
Old 04-11-08, 12:31 AM   #12 (permalink)
mellofelow's Avatar
Interesting... what is it about the OEM unit that gets better reception? I have switched radio in many cars and the Legend was the worse. The odd duck uses 2 antennas maybe that's why.
Whatever it is, I'm about to try this Y adapter and see if the reception is any better. All I have to do is to built up a metal sleeve to fit the smaller antenna.
Old 04-11-08, 12:34 AM   #13 (permalink)
95LegendGS
Guest
Posts: n/a
If you make it work let us know!
Old 04-11-08, 01:03 AM   #14 (permalink)
makes his putts....
Car 2: 1966 Mustang
From my understanding, most aftermarket companies spend the money on the cd section and amplifier section (what most consumers want and use the most) so they use cheaper tuners. The Legend factory radio has a nice, robust built-in tuner. Most factory radios certainly don't have 2 ant inputs. At the time, Acura didn't spare many costs with these cars, or the electronics in them.
Great idea with the ant splitter, let us know if it works!
Old 04-11-08, 01:28 AM   #15 (permalink)
I want K-Sports..
Car 1: '94 Acura Legend LS
Car 2: '91 Honda Accord LX
Send a message via AIM to xpressive
Along with the antenna Y merge, you can buy an adapter that makes that smaller plug a bigger one. GM's use the smaller plug, the adapters are sold at wal-mart, schucks/kragen/checker, autozone, pepboys, etc.. Makes it all plug and play!
1994 Acura Legend LS Coupe Sherwood Green.
-Alpine 9883 -Alpine Type-R -Alpine PDX -17x8 Flik FTD -225/45/17 Nitto NeoGen Tires -Vogtland Springs.
TSX Projector Retrofit w/ DDM 55W Kit
231K+ running strong
xpressive is offline   Reply With Quote
