Old 02-25-08, 02:29 PM   #1 (permalink)
Car 1: 1994 acura
Car 2: 1994 Honda
Car 3: 1986 Fiero
Bose Premium no display
Is the Bose Premium radio in a 94 LS display light bulbs or vacuum tube display? Got the car with no display so I don't know which one it is. I have read that Bose displays have history of going out. The bulb display heads go out because the circuit boards have cold solder joints (which I can fix). The vacuum display heads have a transformer problem (which I can't).
Would like to know which one it is before I take the time to pull the unit.
Has anybody fixed either display without sending it in for a $175.00 repair bill?
jaysacura is offline
Old 02-27-08, 04:41 PM   #2 (permalink)
i just replaced it with an alpine setup
00legendracer is offline
Old 02-27-08, 04:42 PM   #3 (permalink)
but bose is quality so 175 isn't that bad compared to spending 300 for a new alpine
Old 03-03-08, 08:19 AM   #4 (permalink)
Stu
Grand Tourisimo
Car 1: Legend
I have the same problem, but if you fix the Bose and another part of it fails, which is possible, then you have wasted $175.
Spending $125 more for something brand new is well worth it
Stu is offline
Old 03-03-08, 10:13 AM   #5 (permalink)
Go grab your bottle today
nocashrider's Avatar
Car 1: 95 Acura Integra
Car 2: 91 Toyota MR2
Car 3: Hopefully 95 Legend
Send a message via AIM to nocashrider Send a message via MSN to nocashrider
thats true since your sending it in for that problem thats all they are going to fix even if they notice something else they may tell you but they are just going to charge you for that to. the fact that the unit it 10+ its just time to update it if your havin problems
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
nocashrider is offline
Old 03-03-08, 01:07 PM   #6 (permalink)
WINGS + PISTONS
Car 1: 95 Legend L Coupe 6 Speed
Car 2: 94 Integra D15B2
Car 3: 05 Chevy Aveo
Send a message via AIM to Komail
I have the same issue, i just bought another unit off ebay...
Komail is offline
Old 03-03-08, 09:18 PM   #7 (permalink)
Car 1: 1994 acura
Car 2: 1994 Honda
Car 3: 1986 Fiero
Was your unit the premium Bose (it will say Premium on the front) or the standard Bose? I have been able to find out that a lot of the Bose units installed in differant auto makes have a history of bad solder joints on the main board. If the unit has bulbs for the display, and they don't work,, it is a easy fix. If it is a vacuum tub display, it is a part replacement problem. That's why I'm trying to find out which display the Premium has. What confuses me is I have read that the Bose and the Premium Bose are the same head,, only the amps are different.
Was the Ebay unit from a private party or a repair shop?
Normally radio heads don't ware-out,, if they go 2 or 3 years (assuming no moisture problems), they will go for ever. Tape decks, CDs, amps (heat), and bulbs do.
Thanks for your post
J
Old 05-12-08, 09:01 PM   #8 (permalink)
quanaman's Avatar
Car 1: 1994 Legend GS Sedan
Send a message via AIM to quanaman
same problem, but in my 94 GS..
anyone find a solution for this yet? i'd rather not buy a new unit if i can just fix this one..
I'm Parting out TWO Black/Black Sedans. MANY MANY Parts available. PM me.
94' Acura Legend GS
-158k Miles, Timing Belt DONE, Head Gasket: DONE, Tail Light Red-Out: DONE, Tint (35%): DONE, Viper Remote Start/Keyless Entry DONE
Progress Thread<Update! 6/12/08
Future: 2 8" JL Subs+Amp, Ashtray Ipod Dock/Sunroof Tilt DIY
quanaman is online now
Old 05-12-08, 09:30 PM   #9 (permalink)
Car 1: 94' Cheverolet Silverado 1500 V8 5.2L
Car 2: 94' Acura Legend LS
does the radio and tape player still work??
Well mine wasnt working i took the whole thing apart and fixed it with my dad.
There are these things that look like metal tooth picks make sure there all straight and put them each directly into each of there own little holes. Get a solder, wick the lead out and find ur problem.
raginpyro is offline
Old 05-12-08, 09:32 PM   #10 (permalink)
quanaman's Avatar
everything on mine works, it just doesnt light up
94' Acura Legend GS
Old 05-12-08, 09:55 PM   #11 (permalink)
TonyTheBullet's Avatar
Car 1: 1992 Legend LS Sedan
Car 2: 1993 Legend LS Coupe
Just find a replacement on eBay.
(Which one do you have 2100 or 2200?)
ACURA LEGEND OEM BOSE CD CHANGER HEAD UNIT AUDIO JDM 94 - (eBay.ca item 140232365856 end time 18-May-08 22:42:41 EDT)
____________________________________________
PM me if you got 'em!
TonyTheBullet is offline
Old 05-12-08, 09:57 PM   #12 (permalink)
Cassis Red Pearl
EvilRed92Legend's Avatar
Car 1: '92 Acura Legend LS 5spd
Car 2: '90 Jeep Cherokee
Send a message via AIM to EvilRed92Legend
light bulbs? vacuum tubes??? Looks like LCD to me. My display is going dim, which I believe is a common problem. Personally, I'd say get a nice lookin' replacement off E-bay rather then go aftermarket, because unless you can find one that runs 2 Ohms like our OEM instead of the usual 4 Ohms of most aftermarkets, your gonna lose volume and sound quality, from what I undertand. Had 2 different aftermarket units in my car and went back to OEM.
1992 Acura Legend LS 5spd
  • A Legend Reborn.
  • JDM one-piece headlights.
  • Moonroof Tilt Mod.
ISO: OEM Floormats Type J Int. Color.
FS: 2200 radio, 2100 amp.
www.myspace.com/g3rgory
Ebay: eating420seeds
EvilRed92Legend is offline
Old 05-12-08, 09:58 PM   #13 (permalink)
quanaman's Avatar
how can i tell? I have the bose premium in my 94 GS. does year/model make any difference? or do i HAVE to pull it out to check??
94' Acura Legend GS
Old 05-12-08, 10:00 PM   #14 (permalink)
Cassis Red Pearl
Thats the 2100. The 2200 was in base and L. Says on the front of the radio right above the display too.
  • A Legend Reborn.
Old 05-12-08, 11:25 PM   #15 (permalink)
AKA Nicco Bellic
Car 2: 1966 Mustang
Car 3: 06 GTI 2.0 turbo
The factory radio in our cars use bulbs for all lighting. They are super easy to replace as well. At one point i had intended to change the bulbs to LED's, but decided to go a different route. I had it all apart and the bulbs come right out. Go for it.
DevanTheDude is offline
Premium Bose, for Regular Bose Swap. FutureX 2001 Audio, Video, & Electronics 2 04-20-05 11:21 PM
FS: OEM Premium Bose headunit and 6x9 Bose rear speakers Octane OEM Parts 15 10-22-04 07:35 AM
Please help me find out if I have Bose Premium sound system or just normal Bose!! Christopher Audio, Video, & Electronics 4 03-22-04 02:23 AM
Bose Premium Display Problems Steveman09 Second Generation Legend (1991-1995) 1 01-31-04 05:03 AM
Bose Premium vs Non Premium Speakers JamLegend Audio, Video, & Electronics 5 10-16-02 12:27 AM
