» Sponsors
» Sponsors
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-01-09, 12:02 PM   #151 (permalink)
sap
burning dinosaur bones
sap's Avatar
Car 1: 92 LS Sedan AT
Car 2: 93 L Coupe 6MT :(
Car 3: 86 Camaro IROC Z
Send a message via AIM to sap
Originally Posted by trav4517 View Post
The problem i am having is that.
last night my radio and Clock had cut out at the same time. But i noticed if i connect the radio power wire (red) and the memory wire (yellow) they work but of course i loose all presets and clock memory every time i turn the car off. Its almost as i lost all memory in my car. Can anybody help me?
Have you checked for blown fuses? There should be a 7.5A fuse in the under-hood fuse box that would cut the constant battery voltage to the HU if it's blown.
sap is offline
Old 06-30-09, 09:10 PM   #152 (permalink)
Car 1: 1994 acura legend L
Amp or no amp
Hi guys. Read your post on bypassing the stock amp and the location of it. My car is a 94 legend L. I replaced the stock HU with a alpine, the stock was a bose tape deck and read 4ohm on the side, I also have the stock cd changer in the back. The alpine worked for a day then the sound quite. Bench tested the alpine and worked fine so i thought the amp went, problem is i don't believe there is a amp in this car because where you say the stock bose amp should be is another case with four pluges going in to it and on the pass side another case with three plugs. So not sure what the problem is yet. Any ideas? Any help would be appreciated. Thanks
danr355 is offline
Old 07-31-09, 01:21 PM   #153 (permalink)
Car 1: 1991 Gold Legend L Coupe
Questions regarding aftermarket installations
As my standard BOSE head unit is almost completely spent, I'm planning to replace it with an aftermarket system. Now I'm not sure whether my anti-theft system is aftermarket as well. My guess is that it's factory installed as I don't see anything added under the steering wheel or elsewhere in the cabin, and the anti-theft lights on the stereo head unit and door are still flashing.
Questions
1) How will an aftermarket head unit impact the anti-theft system?
2) How will it work with the power antenna (which I'm replacing as well)?
3) There is a 11cm x 19cm space were I to remove the head unit. Can anyone recommend a stereo/cd changer that fits in this space?
Thanks for your time!
1991 Gold Legend L Coupe - Automatic, 162,000 miles (as of 7/09), beige (clean) interior. Car spent first 11 years in Santa Fe and next 3 in Phoenix. Replaced dried out (cracked) engine mounts, repainted vehicle in '04, and moved it to Chicago.
Randy is offline
Old 07-31-09, 03:01 PM   #154 (permalink)
sap
sap's Avatar
Questions
1) The OEM alarm will work just fine.
2) The power antenna will work just fine, every aftermarket deck I've ever seen has an output for raising a power antenna.
3) If you just want a standard sized HU then go to walmart or something and get a kit that'll fit the opening. While you're at it make sure you find a harness adapter so you don't have to hack up the OEM stereo wiring.
sap is offline
Old 09-11-09, 05:12 PM   #155 (permalink)
Car 1: 93 Black L Coupe
Car 2: 91 Red LS Coupe(RIP)
I have the standard bose system and my rear speakers for whatever reason have stopped working so I plan on replacing the front and rear. I'm not familiar with speakers and ohms and so forth and I'm still a little confused. So should I or can I buy speakers that are 2 ohm? or should I buy 4 ohm speakers? Any recommendations, I dont need anything crazy, just something to replace the stock, at least something as good if not better than stock, my headunit is alpine btw.
JTJohnny102 is offline
Old 09-11-09, 06:46 PM   #156 (permalink)
sap
sap's Avatar
A stock system in a '93 L should have 4-ohm speakers, so you should be able to replace the stock ones with pretty much anything on a store shelf.
Whether it'll actually solve your problem or not I couldn't tell you.
sap is offline
Old 09-13-09, 05:58 PM   #157 (permalink)
can someone explain to me about the two way three way and four way speakers..not quite sure what that relates to.
