LinkBack | Thread Tools |
Rating:
Display Modes |
#79 (permalink) | |
Dont Catch
which i suggest. http://cgi.ebay.com/PHOENIX-GOLD-SLD...QQcmdZViewItem |
#81 (permalink) |
MAD DOG!
does anyone know if you have to use the rear window antenna? i gots a sony deck installed and i think they didnt hook it up cuz now my reception sucks... i was thinking about just shaving my antenna mast off and was wondering what i could do to still have good reception without it...
#82 (permalink) | ||
AKA Smartjay28
usualy, the extending antenna is used while the window ant(small plug) is not used. if you wished to use the window antenna, just get the GM10 antenna adapter. good luck
#83 (permalink) | ||
AKA Smartjay28
#84 (permalink) |
MAD DOG!
thanks johnny... but if i do use just the window antenna is the reception gonna be good or what? cuz in hawaii we got a lot of mountains and i hate not being able to listen to the traffic report
#85 (permalink) | ||
AKA Smartjay28
the extending any will be better then the window antenna
#86 (permalink) | |
Legend Lover
. I want to keep my factory HU(2100), straight to an aftermarket amp then to 4ohm speakers. Possible? BTW, Iread this whole thread before asking.
94' Desert Mist Legend LS coupe 86,000mi and counting....... "Life moves pretty fast. If you don't stop and look around once in a while........you could miss it!" Ferris Buller |
#87 (permalink) |
Call me Mister
Yes. You will need to solder some RCA ends on the HU low level output wires that go to the amp, and proceed from there to your aftermarket amp. Here is the wiring diagram for the connections, the ones you will convert are A1-A8...
http://24.96.59.129:8080/LEGENDtuner...o/BOSE_amp.jpg
~ Guy |
#88 (permalink) |
with both antenna's can you splice the smaller one into the larger one so both can be used? Also... i've looked through this tread and never got a solid solid answer. Will the 'remote' blue wire on aftermarket units splice into our steering wheel audio controls and work fine?
93 6-speed coupe soon! |
#89 (permalink) | |
Dont Catch
its a "remote" turn on lead... |
#90 (permalink) |
Thanks for the work put into the stereo FAQ! Nice job! But I, with only basic wiring of stereos experience, have a question about the 2200 unit in my wife's 92 L model. The speakers have progressively died, and now the radio produces only a loud hum. I am assuming from reading posts over the years that the amp is the problem. Does your writeup on bypassing the Bose amp apply to our "standard" system? Or is our amp integrated with the head unit? If I can bypass the amp, what kind of connectors are needed-just flat blades? Thanks, Dave
