LinkBack | Thread Tools |
Rating:
Display Modes |
#91 (permalink) | |
Call me Mister
Since the factory paper cone speakers have come to the end of their service life and need replacing, I would start there. You can use standard aftermarket (4 ohm) speakers. If that doesn't solve the problem, it will be time to repair/replace the factory HU or swap out for an aftermarket unit. There are adapter plugs that make it easy to hook up an aftermarket HU should you choose that route.
~ Guy |
#93 (permalink) |
ok i know i have the 2100 series stereo in a 92 legend but not sure of model yet, i havent picked the car up yet, so im not familiar with the car yet... the tape deck doesnt say premium on it either... i got kind of confused with the whole FAQ on the stereo, but i think im starting to understand it. Main question is, on the 2100 stereo bose non-premium with the 2ohm loads per speaker, what is the best way to replace the factory head unit... my front two speakers are gone and im assuming it is a faulty factory amp and not the speakers... so would i have to also replace all the speakers, headunit and bypass the amp? how would i bypass the amp? thanks....
*edit* i think i pretty much figured it out, LOL just needed to do a little more reading, so i basically just take wires that run into the amp and connect it to the wires that are on the other side of the amp, just color match? and once i replace the headunit, i will have to replace the speakers also right? thanks in advance |
#95 (permalink) |
How do you remove the rear deck to access the rear speakers? I spent a few minutes in the trunk trying to figure it out and came up with nothing. The manual says "remove grills" but they don't seem to want to come off either. Any sugestions?
#96 (permalink) |
On our '92 L model, the rear speakers' grille are hel in place by 4 "tongues" 2 in front and 2 in back. Slide a putty knife (maybe cover the blade with electrical tape to be safe) along the very small gap and you will find those plastic tongues. If you press one of those tongues inward you will see more gap appear, and do likewise with the other tongues. On the amplifier, are you sure there is one on your car? Our L model, with Bose 2200, has the amp in the stereo unit itself, nothing at the rear seat area. I just pulled that unit out and replaced it with a Pioneer from Crutchfield. No damage done along the way, but figuring out the proper installation pieces to use took time.
#97 (permalink) | |
I've owned my 95 SE since 98 and this is the first time I've visited this forum. I was in search for a way to repair my Bose amp that is now making horrible loud noise. From my previous experience with Bose systems, I am quite sure that it is the amp that is my problem. According to the model of my stereo, it is a 2200, which means that it is a standard stereo and not the premium version. Just thought that you may find it useful. Secondly, I'd like to find out how to remove the amp. According to other website, it is located below the head unit. TIA for your help! |
#98 (permalink) | |
Call me Mister
Removal instructions here... http://ww2.legendtuner.com:8080/LEGE...ifier/amp.html
~ Guy |
#99 (permalink) | |
I'm fairly sure that it is a factory SE. I purchased the car from an elderly gent. when the car had only 16k miles. So I find it hard to believe that he had changed the stereo. I'll go home and remove the back seat to see if it has an amp there, but the stereo is for sure a model 2200. You've been a great help. Thanks! |
#100 (permalink) |
Hey Folks,
Great thread! I will be replacing my speakers (finally) on my 03 LS Coupe. I was going with the Kappas 6x9s and 6.5s - 3 ways - 2 ohms, keep the amp and head unit. It seems like this route is the lease trouble but should improve the quality of sound a lot. Correct? Does anyone have this setup? How does this sound? My CD changer just went out. I picked up a Mbus adaptor for my iPod. I am debating whether or not to replace the CD changer with the iPod or to purchase a new changer. They are very reasonable $90 (used) - $150 (new). I don’t think the quality of the iPod sound will be the same as a CD BUT we’re in a car…Will I be able to hear the difference? Does anyone have either of these setup? How does this sound? Is there a Mbus splitter? Something where I can have 2 sources and toggle back and forth from CD to iPOD? Any thoughts would be appreciated. |
#101 (permalink) |
AMP verification 95 L Coupe
I have a 95 Coupe L (Type II) with OEM Bose system -- which has an amp behind ls rear seat. It can be accessed, and removed, btw, w/o removing rear seat; rather just gently move rear panel.
Problem: how can you verify if amp is working correctly....I changed out OEM head unit with OEM unit (92 4-dr unit), due to dimming radio read-out, and loud hum. Everything works but not strong power -- need lots of vol., and appears amp not working...? Ron In Ottawa, Canada |
#103 (permalink) |
hey i just read your diagram and saw a cd cable - i was told by ma boy at work that u can have a caset player but a 6cd changer in the trunk can i do dat cuz he told me i culd get on in the junk yard fo cheep - is so wat cd changer can i get and is it posible to do that in ma car i got a legend 91 ls 4dr i think is LS or L lol.....
#104 (permalink) | ||
Obsessive Enthusiast
Also, read the thread that you're posting in as it answers your question. Quote:
ADDCO | MLS | KNUKONCEPTZ | ALPINE | ECLIPSE | JL AUDIO | BOSTON ACOUSTICS might be selling: pm me if you're interested in a well cared for, well running, high mileage sedan |
#105 (permalink) |
need help on taking out a factor deck. i bought a 92 legend. i dont know what model it is but thing is a pain in the butt to take out. am i supose to remove the whole frame of the center to get it out? i tired but broke a nail. would someone help me out because im about to just yank that thing out with a crow bar.
