FRISCO LEGEND BABY!!!!
Hooking Up 2 Amps For Each Sub
I got a question, is it possible to hook up the left sub with 1 amp, and the right sub with 1 amp? Basically the subs get their own amp. Is this possible?
\18" Limited 341 Chrome Rims/\Matador Red Paint/\Weapon R - Secret Weapon Intake/\LED Bright White Dash Lights/Floor/\Kenwood KDC-X590 Excelon Mp3 Deck/\Ford Taurus Coin/Cup Holder/\2 12" Kickers/\1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp/\2 Rockford Fosgate Capacitors/\Power Acoustic Capacitor/\Clear Rear Turn Signal/\Reverse Glow Gauges/\Swapped 88' Headlights to 89'-90'/\JDM Rear Chrome Trim/\Stromung Muffler/ Soon To Come: Rebuild Motor and 5-MT Swap
i think what you're asking is can you run 2 subs off of 2 amps, with each sub having its own amp. yes, its possible. i did this back when i had 2 cheap amps. you will probably want to bridge each amp to get the sub the most power.
Roll that seven duece Cutlass, can't touch this Vogues smoke like dope when I say fuck this Roll my windows down, still smoke tinted Shot gun mag glocks all up in it I have an ECU, Sedan type F door panels, Gauge clusters, Digital climate control, Type 1 Intake manifold, Injectors, Coil packs, and a tail light for sale http://www.acura-legend.com/vbulleti...iendly-127973/ |
It's good to be the King!
If you have the amps already just laying around....sure, you can do it. IMO I would suggest you just buy a bigger amp.
You will need to RCA pre-outs form the radio, or a splitter (one set for each amp) Once you have that its just a matter of power and speaker wire. Depending on wattage you'll want to run a 4guage (with its own fuse in the engine compartment) to a fused distribution block to power the amps. You can splice the remote wire to work for both amps. If you have a 2 channel amp you can bridge it (if the amp is built to allow for bridging) as stated above for more power. If its a 4 channel you will be wasting 2 channels.
95 Acura Legend L, 5-spd, custom Type F interior. |
very possible..in fact its the best way to go..hopefully you have 2 mono amps of the same powe..you dont want to give them different wattage...and its not necessary to have to use 2 rca cables from the HU..if your amp is kind of a newer model..it should have in and out puts..if you do..then you can put an rca from the out to the other amp...if you have a 2 cha amp then bridge it like the others said..and if you have a 4 cha amp..then i dont recomend it....
K I found out what amp I have and here it is:
Product Information The XM-2200GTX 2-channel amplifier puts this reliability to good use with 200 watts RMS power per channel (or 500 watts RMS bridged), plenty of power for a subwoofer or two. The variable bass boost (0-10dB at 40 Hz) kicks up the lows when it's needed, and you can switch on the variable low-pass filter to keep the low frequencies tight and crisp. Product MPN MPN= xm-2200gtx Key Features Amplifier Type= Dual Channel Bridgable= Bridgable RMS Power at 4 Ohms= 200 W x 2 Performance Frequency Response= 5 Hz - 50000 Hz THD at Rated RMS Power= 0.01 % Crossover / Equalizer Bass Boost= With Bass Boost Bass Boost Frequency= 40 Hz Low - Pass Frequency= 50 Hz - 300 Hz Other Features MOSFET Circuitry= Yes Dimensions Width= 15.75 in. Depth= 10.88 in. Height= 2.25 in. I bridged this amp before and let me tell you, it shut off in about 20-30 min. cause it got hot pretty quick. So I was thinking of getting the same amp. What do you guys think? Oh, and I'm running 2 Gauge power wire and my ground is a 4 Gauge.
#7 (permalink) | ||
AKA Smartjay28
I need to find out what kind of kickers I got, but they are 12" kicker cvr. I'll find out the ohm on them.
| hooking up subwoofer | 2.7legend | Audio, Video, & Electronics | 10 | 10-30-05 09:20 PM |
| Hooking up an amp | bobs92ack | Second Generation Legend (1991-1995) | 3 | 02-27-05 01:19 PM |
| Hooking up Nitrous to Throttle | Plopper | Engine & Performance Modifications | 13 | 07-19-04 11:21 PM |
| hooking up aftermarket stereo! | TPR10 | Audio, Video, & Electronics | 6 | 12-18-03 02:33 PM |
| Hooking up amp to Bose wiring | simgarcha | Audio, Video, & Electronics | 1 | 08-09-02 04:47 PM |
