Old 07-12-04, 08:33 AM   #1 (permalink)
GIN NSX
MikeC's Avatar
Car 1: Former owner of a 6 Speed Coupe and a GS Sedan - Daily Driver 2005 Tacoma 4 Door / Weekends an NSX
I want to upgrade my rear speakers for my 94 "L" Coupe
I would like to replace my factory rear speakers (the right rear is blown) from my 94 "L" Coupe with an aftermarket speaker, while retaining the factory head unit. Has anyone upgraded their rear speakers (for that matter front speakers as well) with an aftermarket brand? If so, which mfg did you use and did it drop in without any cutting into the factory location?
Thanks in advance for any assistance.
MikeC
MikeC is offline
Old 07-12-04, 10:12 AM   #2 (permalink)
Car 1: 1995 Legend L - Cashmere Silver
From what I've noticed, no after-market speakers fit perfectly. MB Quart comes damn close. The screw holes dont match exactly to the plastic, but you can jimmy-rig them to fit. The best way that i have found is to remove the plastic and manipulate the speaker to match the holes as close as you can.
QB175 is offline
Old 07-12-04, 10:18 AM   #3 (permalink)
Vrooom
Car 1: 1994 L Coupe
Send a message via AIM to 94LCoupe
My advice from an SQ point of view, would be to not use rear fill...Just run front speakers...
94LCoupe is offline
Old 07-12-04, 11:53 AM   #4 (permalink)
GIN NSX
MikeC's Avatar
Thanks for the reply... Which model MB Quart did you install?
MikeC
MikeC is offline
Old 07-12-04, 11:54 AM   #5 (permalink)
GIN NSX
MikeC's Avatar
Which Aftermarket speaker would you recommend for the front, using the stock head unit? Please provide model / part number/
Thanks,
MikeC
MikeC is offline
Old 07-12-04, 12:16 PM   #6 (permalink)
Car 1: 1989 L Sedan
People who are really into car audio SQ typically run high powered speakers just in the front and a subwoofer in the back. They best way to do it is to put the front speakers down in the kick panels with custom enclosures. The problem is, to really get good sound, you can't use just your head unit's power. You would need an external amplifier and probably a set of component speakers (tweeters are separate from the drivers and an external crossover is needed). You'll also need some sort of sub-woofer in the trunk for the lows. This will need to be amplified as well.
I've had systems like the one described above and the SQ is REALLY good. It costs a lot of money though, and it takes a lot of tweaking to get just right. It can be frustrating until you've found the right mix of components for your particular car.
When I got my '89 Legend Sedan recently, I replaced the factory cassette deck with my 3 year old Eclipse CD player. Then, I replaced the factory front speakers with a set of Eclipse 8263 coax speakers (6.5 inch) that I had from a while ago. In the back, I put in a set of old Boston Acoustics 767 Coax speakers (again, 6.5 inch). Every thing was VERY easy to install, no external amplifiers and no running power cables to the trunk and RCA cables from the front to the back, etc.... And also, no subwoofer. This setup sounds GREAT. I listen to it for at least an hour a day while commuting.
You can't get the speakers I listed above anymore, they're pretty old now. But I know both companies (Boston Acoustics and Eclipse) still make reasonably priced coax speakers in many sizes. MB Quarts are good too. Just remember, if you plan on using speakers that are only going to be powered by your factory head unit, you don't want high powered speakers (100 or 200 watts). Find some that are 30 to 40 watts RMS and maybe 100 watts max.
Good luck.
Steve
1989 Legend L Sedan
156K
commuter is offline
Old 07-12-04, 03:44 PM   #7 (permalink)
GIN NSX
MikeC's Avatar
Good luck.
Steve
Steve,
Thanks for the info and advice... Even though it was my rear speaker that went bad, I am willing to replace all factory speakers with aftermarket as long as they drop right in with very little modification and they allow me to use the factory head unit.
MikeC
MikeC is offline
Old 07-12-04, 07:06 PM   #8 (permalink)
0000$$$$0000####0000
Car 1: Acura
The front's are easy. Any 6.5" will work up front. Depth can matter but all you need to do is cut out the back of the plastic mounting basket and you will have more then enough depth to accomodate almost every 6.5" speaker. Yes, it is true that the mounting holes will not line up with most aftermarket speakers. Not a problem. Use some LB weld or similar epoxy and simply fill in all the holes and hollow areas around the stock plastic mounting basket. Now just drill your own holes.
For the rear, You just need to measure the maximum depth the rear can take and find a speaker that will fit. Better yet, buy a matching set of 6.5" as the front, make a flat moutning plat to cover the 6X9 opening (This will mount to the stock 6X9 mounting trim), then cut a hole in the center for the matching 6.5" speaker. You probably would be better over all sound anyway. I would also line the underside of the 6X9 with some sound dampaning material to creat a somewhat sealed enclosure. That will definately help in the low end response.
Any 4 ohm aftermarket speaker will work with the L model 2200 deck you have.
ChrisK is offline
Old 07-13-04, 07:15 AM   #9 (permalink)
I Steal Gummi Bears
kostas86's Avatar
Car 1: Boxster S, Subaru STi, Subaru WRX, AMG E55, Benz E320 Coupe, & Benz 190e
Kenwood speakers should easily fit in without cutting and I would recommend you take a look at them at Best Buy. I have installed Alpine speakers in my Legend and they also easily fit in.
"At the feast of ego everyone leaves hungry"
"Run your car not your mouth"
kostas86 is offline
Old 07-13-04, 01:57 PM   #10 (permalink)
Vrooom
Car 1: 1994 L Coupe
Thanks,
MikeC
A lot of people like the Infinity (6002i) Reference Series 6-1/2" Speakers...The only complaint I have with them is that the midbass is a little lacking, and the tweets can get a bit bright...But they sound nice with deck power...
94LCoupe is offline
Old 07-13-04, 01:59 PM   #11 (permalink)
Rally *ar Needed!!
claus44's Avatar
Car 1: now buckled up in SC400
Send a message via MSN to claus44
the pioneer 6x9s that i had in my L sedan fitted perfectly.... even the screw holes lined up.
Yes, for best SQ and staging it is best to run just the 2 front speakers. However, most people will feel that the music is "dry" with this kind of setup. The best way to compensate this will then be pushing the fronts with high power amps and run the rears with the build in amp of the headunit. Or, you can simply use the fade.
If you are willing to spend the money and are looking for a deal, thezeb.com has the CDT EF-61 for only $167 right now. That's a crazy discount from the regular price!! If you don't plan to run an aftermarket amp right now, then just get the CL-6X.
If you want to spend even more, ask Graeme and he'll tell you who can get you some DynAudio speakers
92 SC400
NGK Iridium, BFI, TRD 1.5Kg/cm^2 Rad Cap
Espelir ASD, Tockico HP, Daizen Bushings in LCA & ASB
Carbing JDM One-Piece STB, Stock Color CF Hood, & Oddesy Battery
Eclipse CD5441(soon to be Alpine BlackBird w/ IVA-W200 w/ PXA-H701), CDT all around(Soon to be Seas Lotus Ref), Audison VRx2.250.2, ID10D2V.3, PG Tantrum 300.2
Excessive Amperage 200 Amp HO Alt
Clifford IntelliGard 7000,Ground Wire Kit
claus44 is offline
Old 07-14-04, 03:39 PM   #12 (permalink)
GIN NSX
MikeC's Avatar
ChrisK, thanks for your reply... If I cut out the back of the mounting basket, will that change the sound coming from the speakers? I'm guessing since they would be hooked up to the factory deck, it wouldn't matter.
MikeC
MikeC is offline
Old 07-14-04, 03:48 PM   #13 (permalink)
GIN NSX
MikeC's Avatar
Thanks for the recommendations...
kostas86: Are you referring to front speakers or rear speakers. Do you have the part / model numbers for the Kenwood and Alpine?
94LCoupe: Did the Infinity Reference Speakers drop right in or did you have to cut out the back of the basket?
MikeC
MikeC is offline
Old 07-14-04, 03:52 PM   #14 (permalink)
GIN NSX
MikeC's Avatar
Brian: Do you remember what the part / model number of the Pioneers were? Since I will not be running a high powered amp (I just want to replace the factory speakers with aftermarket speakers that will be powered from the factory head unit) I will probably go with the CDT's CL-6X.
Thanks,
MikeC
MikeC is offline
Old 07-14-04, 04:18 PM   #15 (permalink)
Vrooom
Car 1: 1994 L Coupe
MikeC
Depth isn't a problem...Those speakers are 2.56 inches deep...I managed to fit JL XR mids which are 2.81 inches deep without a problem...
94LCoupe is offline
WTB: Front and rear bumpers, or covers for '92 LS Coupe repo'd OEM Parts 2 10-25-03 07:07 PM
rear speakers JTJohnny102 Audio, Video, & Electronics 5 01-10-03 05:24 PM
8in rear speakers for those w/G1s acpac_jet Audio, Video, & Electronics 1 11-11-02 06:29 PM
What speakers have people installed in rear of 93 Legend L Sedan? tomas Audio, Video, & Electronics 3 08-16-02 04:40 AM
1993 Acura Lengend L Sedan Rear Speakers ???
