Old 06-08-04, 07:01 AM   #1 (permalink)
Car 1: 1995 Acura Legend GS
just bought an amp and speakers someone help answer some basic questions?
ok i bought 2 punch 12's in a box with a 250 watt punch amp, the amp is already mounted to the box and hooked up to the speakers but i have some questions about how its hooked up and what settings to use.
--First there are 2 outputs L and R for speakers ouputs on the amp he has both speakers linked togather and wired into the R output and nothing wired to the left, he also has the crossover setting on LP (HP-Full-LP are the options) is this setup right ??? i know nothing about amps or speakers but it looks kinda weird.
--What crossover frequency setting should it be on???
--also there is a wire labled REM and it is spliced into the + wire that goes to the battery is this correct???
if someone could help me answer these questions that would be much appriciated.
144,000
My ride
Roger is offline
Old 06-08-04, 08:04 AM   #2 (permalink)
Legend
Car 1: Cobalt Blue Pearl
Send a message via ICQ to u2vex Send a message via AIM to u2vex
L and R outputs are you Left and Right speakers connections, it may be bridged by using both channels, neg from one channel and positive from the next (not sure which L/R for Neg or Pos, maybe someone else can get that)
Crossover setting on LP is for Low Pass Frequency (BASS), Hp is for High Pass Frequency (TREBLE), FULL is everything.
REM is your Remote, something like your ACC, usually wired(splice) from the headunit to turn on the AMP when you power your head unit.
hope this helps you out...
u2vex is offline
Old 06-08-04, 08:39 AM   #3 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
Car 2: 5G Accord i/h/e
Send a message via AIM to jigga225
as far as him taking one spkr power from the R and one from the L, he was bridging the amp, which makes it put out more power. It safe as long as you arent runing your amp too hard by wiring it wrong. if both speakers play, and the amp never heats up and cuts off, then it's probrably done correctly.
For your subs, your crossover should be set on LP, and around 80Hz to give a nice punch.
NO, the REM (remote, which tells the amp when to come on)wire should be SEPERATE from the one that goes straight to the battery. If you connect them to the same, the amp will never cut off, thus draining your battery when you're not in the car.
REM should be connected to a positive wire that ONLY comes on when the car is on. (you can splice the radio/power antenna power wires for your REM)
any other ?'s ...just holler.
^Work^............................................ ............................................^Play^
jigga225 is offline
Old 06-08-04, 08:40 AM   #4 (permalink)
thanks for info but im still confused at the way he has the amp setup now there is a left speaker output, with a neg and pos slot and a right speaker outlet with a neg and pos slot and he had both the 12's hooked togather going into the right speaker outlet and no wires at all going into the left speaker outlet.
144,000
My ride
Roger is offline
Old 06-08-04, 08:52 AM   #5 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
that's not realy the right way to bridge em.
what kind of woofers do you have ?? 2 12" i know but are they DVC (dual voce coil?) probrably 4 terminals on each speaker
or SVC (single voice coil) 2 terminals on each speaker.
either way, you dont wanna bring that punch amp down below 4 ohms.
Tell what kinda woofers they are and i can explain more
jigga225 is offline
Old 06-08-04, 09:27 AM   #6 (permalink)
there are 2 wires comming from each speaker then he has the neg on one the the neg on the other hooked togather same with the pos them they hook into the right speaker output neg and pos terminals.
144,000
My ride
Roger is offline
Old 06-08-04, 11:16 PM   #7 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
go to the 3rd page in here-> http://iweb.alpine-usa.com/html/asb/...r-1221d_om.pdf
its alpine but it shows diagram on couple of ways to hook up your sub to your amp.
Johnny Kim is offline
Old 06-09-04, 01:34 AM   #8 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
well since you're using a rockford amp. they cant be bidged to lower than 4 ohms mono.
so your best bet would be to hook them straight up, one speaker to the left terminals of the amp (+ to + and - to -)
and then the same on the right side with the other spkr.
jigga225 is offline
Old 06-09-04, 01:40 AM   #9 (permalink)
Vrooom
Car 1: 1994 L Coupe
Send a message via AIM to 94LCoupe
In theory if he bridges the subs correctly(at 4ohm mono), or runs them 2ohm stereo he should get the same amount of power...
That is if he has each sub wired at 2 ohms...
-Brian
94LCoupe is offline
Old 06-10-04, 07:55 AM   #10 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
if he runs em 2 ohm stereo, he'll only be able to use one channel because he has only 2 (4 ohm)_ speakers
therefore it wont be the same power as running 4 ohm mono.
Plus, rockford amps Love the 4 ohm mono configuration, they almost "double" their power when ran that way, versus stereo configs
jigga225 is offline
Old 06-10-04, 08:51 AM   #11 (permalink)
Rally *ar Needed!!
claus44's Avatar
Car 1: now buckled up in SC400
Send a message via MSN to claus44
don't run the subs in stereo mode when they are both in the same box!!
92 SC400
NGK Iridium, BFI, TRD 1.5Kg/cm^2 Rad Cap
Espelir ASD, Tockico HP, Daizen Bushings in LCA & ASB
Carbing JDM One-Piece STB, Stock Color CF Hood, & Oddesy Battery
Eclipse CD5441(soon to be Alpine BlackBird w/ IVA-W200 w/ PXA-H701), CDT all around(Soon to be Seas Lotus Ref), Audison VRx2.250.2, ID10D2V.3, PG Tantrum 300.2
Excessive Amperage 200 Amp HO Alt
Clifford IntelliGard 7000,Ground Wire Kit
claus44 is offline
Old 06-10-04, 09:03 AM   #12 (permalink)
so what way should i have it hooked up??? i guess it dosent really matter cause right now the 2 speakers are hooked togather making them 2 ohm then hooked to the right outlet of the amp
--ps what cant u run stereo if the speakers are in the same box??
144,000
My ride
Roger is offline
Old 06-11-04, 05:44 AM   #13 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
run one speaker to the left side of the amp.
and the other speaker to the right side of the amp.
You cant bridge those speakers with that amp because it will heat up and cut off eventually.
i dunno what the hell caus44 is talking about.
jigga225 is offline
Old 06-11-04, 06:45 AM   #14 (permalink)
why do u say that??? the back of the amp says u can run it at 2 ohms so i dont see a prob with them being bridged?
144,000
My ride
Roger is offline
Old 06-11-04, 07:28 AM   #15 (permalink)
I swag it out...
jigga225's Avatar
Car 1: 95 Legend LS
does the amp say...
2 ohms bridged
or
2 ohms stereo
i mean, correct me if i'm wrong. But i thought rockford amps are to be ran bridged at 4 ohms.
The way you have it hooked up now (all 4 speaker wires on one side of the amp) is running 2 ohms stereo
jigga225 is offline
Aftermarket HU and speakers... will an amp help? Volk Racing Second Generation Legend (1991-1995) 30 07-22-04 03:52 AM
running aftermarket amp for front speakers on premium bose system? Tim92LS Audio, Video, & Electronics 1 06-03-03 10:13 PM
