Old 03-18-08, 11:09 PM   #16 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
ummm no. since you'll see the metal frame and everything. unless you do some fiberglass work... or want your car stolen... id say dont do it that way.
**Anti Alpine Type-R Thread**
bl420 is offline
Old 03-19-08, 01:19 AM   #17 (permalink)
custom box builder
Send a message via AIM to pwnt by pat
What you can do that will turn out very nicely is to make a baffle that bolts to the rear angled supports behind the rear seat backs and mount your woofer on there. IF you seal off the rear deck and this baffle well enough, your entire trunk will act like a box. This method of install is typically called infiniate baffle and is a very classy way to install a sub without taking up any space.
pwnt by pat is offline
Old 03-19-08, 11:07 AM   #18 (permalink)
im a dippidy do-er
foolonrampage's Avatar
Car 1: '91 Acura Legend L
Send a message via AIM to foolonrampage Send a message via Skype™ to foolonrampage
would it really sound that good?? its not air tight or anything.
foolonrampage is offline
Old 03-19-08, 11:51 AM   #19 (permalink)
custom box builder
Well the thing is you have to make it air tight. The baffle is typically two layers of 3/4" mdf and has to be bolted several places to the car. The air gaps need to be sealed with deadener and expanding foam.
Pittsburgh Audioworks: enclosure design, fabrication, fiberglassing and mobile customization
Old 03-25-08, 02:49 AM   #20 (permalink)
AKA Nicco Bellic
Car 2: 1966 Mustang
Car 3: 06 GTI 2.0 turbo
This thread made me think about some old plexi work Ive done so I had to dig this out-
[IMG][/IMG]
A 5'8'' thick grill for a Diamond 15" D3 sub. Heres a link to the system.
More Screens and Lights!!! - UPDATED SEPT 2005 - , US
wow. a trip down memory lane.....
DevanTheDude is online now
Old 03-25-08, 11:50 AM   #21 (permalink)
im a dippidy do-er
so, DEV. what are you thinking?? should i go with a custom box or will i be getting in over my head? im only hoping to spend at MOST $200 for a custom box. and i would do all the work myself...
thats some sick work too man. kudos
Old 03-26-08, 12:54 PM   #22 (permalink)
Cure Hunger:Soylent Green
GrumpySteelMan's Avatar
Car 1: 2004 Nighthawk RL
Car 2: 2005 Nighthawk TL
Car 3: 2002 525i Sport Wag
I've got some of Devan's experience. Reformed MECP and Rockford Institute grad here...worked for an independent shop for a few years.
Full plexi is tough to make look right. Plexiglas is optically transparent (unlike most glass) so it is really unforgiving at seams and overlapping points. A window would be your best bet. If you're really into taking the time, and cutting holes...mounting the subwoofers in the rear deck (don't know about 12" fitting) with grille cloth covering them would be a really trick way to go. Then you can show off the baskets with the lighting in the trunk. One of my personal favorites is suspending the box from the rear deck so you still have a larger flat load floor and can even use the ski pass thru/fold down seats depending on application.
A nice compromise is building a ported box Ported Box Calculator and running the ports into the cabin of the car. This can give you a certain amount of 'cabin gain' and lower the distorting effects of the subwoofers pounding on the back of your rear deck mounted speakers.
I don't agree with pwnt by pat. Building your box as part of your car isn't what you really need, IMHO. Also your Kenwood subs (and most others) are probably designed to be in a box (model #?) as IB or infinite baffle speakers are generally designed for that use only.
Just my 2cents.
P.S. Try to isolate the neon tubes from the vibration as much as possible, especially if they have the ballast built in. I've had some pretty regular failures due to the cheap transformers in the assemblies giving up. Either way make sure you can get back to them.
200 Degrees, that's why they call me Mister Fahrenheit.
There is no Alice, there is no Wonderland, there is no Mad Tea Party, the Wishing Well ran dry....but you can still EAT ME.
GrumpySteelMan is offline
Old 03-26-08, 01:43 PM   #23 (permalink)
Car 1: 94 GS sedan
You can check out my box at the link below is made out of MDF and plexi.
http://members.cardomain.com/dtran
legendgs94 is offline
Old 03-26-08, 03:50 PM   #24 (permalink)
Matthew is THE USER!
mktng's Avatar
Car 1: 91 KA7
Car 2: soon2b GIXXER 750!!!
how do u get'em puuuuuurdy blue lights? lol
how are those connected to ur amp/battery. and are they cathode lights from computers?
i decided to keep it nice and simple, so i can make use of my trunk. the amp and cap are tucked away behind the cover separating the trunk and the back of the rear seats
as u can see there is still sufficient room to move stuff, most ive moved so far with the sub in there are 4 17" tsx rims w/o tires
mktng is offline
Old 03-26-08, 10:24 PM   #25 (permalink)
Coming soon :D
Smokinfastlegend's Avatar
Car 2: Diamond Audio
Car 3: ATL LEGENDS!
You could always do a box similar to mine:
Legendary Detailing
Honda had fun designing the window visors for the Japanese Legend. It wasnt to be installed without injury. They absolutely wanted you to destroy your finger tips.
Looking for foglights for your 94/95 Coupe/sedan?
Smokinfastlegend is offline
Old 03-29-08, 11:59 AM   #26 (permalink)
im a dippidy do-er
im hoping to have my subs facing towards the cab. it makes for a MUCH better sound. and im hoping to get Plexi in the back. but i love your set ups mktng and SMokin!!! very clean!
Old 03-30-08, 12:32 PM   #27 (permalink)
mktng's Avatar
Car 1: 91 KA7
thanks, yea the legend is good cause of the huge trunk.. i wanted to keep it clean so i can actually use it
btw with the subs.. i took out the spare... woowoweewow... too much weight in the back
mktng is offline
Old 03-31-08, 03:36 AM   #28 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Your gonna hate yourself when you get a flat tire one day. Thats what I did when I took my spare out. I had to wait for my dad to come drop off the spare. Now I have it back in the trunk.
My Legend Is Rising Back From Hell!!!! BEWARE.
18" Limited 341 Chrome Rims
Matador Red Paint
Weapon R - Secret Weapon Intake
LED Bright White Dash Lights/Floor
Kenwood KDC-X590 Excelon Mp3 Deck
Ford Taurus Coin/Cup Holder
2 12" Kickers
1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp
2 Rockford Fosgate Capacitors
Power Acoustic Capacitor
Clear Rear Turn Signal
Reverse Glow Gauges
l4zy415 is online now
Old 03-31-08, 09:17 AM   #29 (permalink)
Renaissance.
whats77inaname's Avatar
Car 1: 91 5MT LS, 271k
Car 2: 91 5MT LS, 183k
Car 3: 03 G35 sdn (wife's)
I picked up a 1" thick piece of plexi that was 60" long and 12" wide for $50 on eBay. I haven't finished it out yet, but you can see what I am working with.
Originally Posted by ~Sun, Tsu, The Art of War
"Let your plans be dark and impenetrable as night, and when you move, fall like a thunderbolt."
Originally Posted by sourdiesel View Post
I don't keep a bat in my trunk for surprise games of baseball...
whats77inaname is offline
Old 03-31-08, 04:28 PM   #30 (permalink)
mktng's Avatar
Car 1: 91 KA7
i got tire repair kit .... it'll help for couple km's .. unless i rip my tire apart >.<
mktng is offline
