Old 05-09-02, 09:06 PM   #1 (permalink)
Send a message via Yahoo to simgarcha
Wiring to amp
I am in the process of upgrading my Bose deck in my Legend to an aftermarket deck. When I get the deck installed, I want the installer to run the RCA cables to the back (where the original amp used to be). I heard from someone that the wires should be run on the opposite side of the power cables to avoid any "NOISE". If this is true, could someone please tell me which side I should run the RCA cables on? Thanks.
Sim Garcha
1991 Acura Legend LS Sedan
simgarcha is offline
Old 05-11-02, 11:43 PM   #2 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
Since your battery is on the drivers side, you should run your power wire down the drivers side. RCA's should be ran down the passenger side. take your time, make sure you don't break anything and you should do ok. If you run into problems, just post and I'll coach you through it.
Mike Diaz is offline
Old 05-12-02, 12:25 AM   #3 (permalink)
WhiteLegend's Avatar
Yeah, you want to run RCA's down passenger side. Never run RCAs and Power side by side, you will have noise most of the times. If you come to a point where the 2 lines have to cross, make sure to cross them in a perpendicular manner, reducing the likelyhood of noise.
WhiteLegend is offline
Old 05-15-02, 03:43 PM   #4 (permalink)
who's yo daddy!
Kurizma's Avatar
Car 1: 2002 Velvet Beige Altima 3.5 SE 5-Speed
Send a message via AIM to Kurizma
Is wiring the remote bass control wire (The phone like cord) next the the RCA cable ok? Also, where else would be a good way to route the RCA cables back to the trunk? I have one along the passenger side but there is no more room for another RCA Cable. I'm planning on upgrading my Deck and running more RCA cables from the new deck to my 4 channel amp which is using the high inputs right now.
91 Sedan LS (traded for 2002 3.5 5-speed Altima)
still wanna 93-95 coupe
Kurizma is offline
Old 05-15-02, 04:34 PM   #5 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Running the bass control wire next to the RCA's should be fine.
What I did in my last coupe was I took the entire interior out, carpet and all. I ran all the power and ground wires (had 2 different grounds, one to the battery, one in the trunk) down the driver side floor, under the front driver seat, then under the rear carpet, then under the rear seat. All RCA's (had 3 sets) ran down the passenger side under the passenger seat, then under the rear seat.
That was the only way to eliminate engine noise and Power inverter noise from my system. You'll probably have to do this since you're running a line driver. I had an AudioControl Three.1, Monitor, PS2, VCR, and a power inverter though.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
