Go Back   The Acura Legend & Acura RL Forum > Off Topic > The Lounge > Computers
Computers Computer acting up? Have software questions? Post them in here!
Old 11-10-05, 03:48 PM   #1 (permalink)
Car 1: 1992 Seattle Silver LS
Wireless Network PCI card issue
I bought a new wireless network card (Trendnet TEW-423PI, 802.11 G) and about once a day it will just lose connection. Usually after about an hour or so of heavy net use (Limewire, IM's, Internet) it will just quit working. I can check the wireless connection status and everything looks normal except the activity will just stay gray (Blue is what it shows when its working). So i have to restart my PC and then, just like that it will work again. Its frustrating to do this everyday, does anyone have an idea of what i can do? For system info, I'm running XP pro, on a Pentium 4, 2.6mhz, 512mb of ram. Also when i try to disable the wireless adapter that function locks up and i usually have to use the power button to shut it off. (Will not shut off through start menu)
Formerly "Civic2Legend"
http://www.geocities.com/bigballer_78250/sig.txt
Phil B is offline
Old 11-10-05, 04:20 PM   #2 (permalink)
Victory is fleeting...
duck's Avatar
Car 1: 2007 Honda Ridgeline
Make sure you have the most recent drivers, that's a biggie. Also, open computer management, select device manager in the left-hand pane, on the right-hand look for network adapters and find your network card in the list...right click it and select properties. A window with tabs at the top will open, each card can have a different set of tabs...generally there will be an "power managemtn" tab, select that. Uncheck any boxes that are checked. Remarkably, Windows will turn off a NIC to save juice even if the NIC is transmitting data. When done, keep clicking okay until all windows are closed.
Rythmic, systemic and world control Magnetic, genetic, dement your sou...
duck is offline
Old 11-10-05, 04:49 PM   #3 (permalink)
Thanks for the info. Before i wrote this i did update the drivers, and it doens't happen as often but at least once every 12 hours. Also i checked the setting for power management and it said "Constantly awake". The only other things i can change are the Preamble select (have no clue what this is) and the Fragmentation/RTS threshold (have no clue what those are either). Thanks again though.
Phil B is offline
Old 11-10-05, 09:13 PM   #4 (permalink)
Registered Driver
Black_Panther's Avatar
Car 1: 88 S3dan
Standard level for rts threshold is 2,347bytes; this threshhold deals with fragmentation of frames which becomes necessary when you have more than one wireless client on your network and when those 2 clients are far enough apart that they cannot detect each other(in seperate rooms). This can lead to collisions in communication...its like a few people all trying to talk on a cb at the same time. Decreasing this value can help if you have a lot of interference around (2.4ghz phones that hop frequencies and crappy microwaves mostly).
Preamble is simpler, it simply syncronized communication to make things go smoother..kind of like a go ahead
You generally dont need to worry about either of these settings though
One setting I'd reccomend you change is on the router itself
Lock it into 802.11b and not g this will give you a bit more range and a more stable connection overall. moving from 54 to 11mbps isn't a big deal unless you're doing lots of home networking.
BP
Black_Panther is offline
Wireless Network Problems Daddymac117 Computers 29 01-02-05 08:47 AM
Wireless network info Daddymac117 The Lounge 2 11-01-04 07:44 AM
Privacy Watch: Wireless Keyboards That Blab enigma The Lounge 2 06-24-04 06:11 AM
difference between PCI and AGP video card? Esti The Lounge 11 12-19-03 03:36 PM
PCI to PCMCIA Card Nutoy The Lounge 6 06-04-03 09:40 PM
