| Automotive Discussion Discuss Automotive News & anything auto related. (No RL or Legend discussion!) |
Mexican American!!!!!!
i really need help on this one!!!!!
ok i have a problem! 1999 pontiac grand am gt! it dont start! well it does but for only 1 second! i heard that these had some kind of security issue! any help would be appreciated!
b.t.w. i already changed wires plugs and fuel pump! please help a brother out!
Admit the obsession
try unplugging the battery for 20-30 min and then try to start it. It worked when the cavalier wouldnt start with the same symptoms
Finally back in an Ac. 91' pearl white legend coupe 6K HID's, intrax springs, weaponR intake, tint, excessively loud exhaust 17" TL wheels GS style Piaa fogs |
did it! same prob! getting fessed(sp) up with the car! not even my car! its my sisters car! she unemployed so really trying to help her out!!!anybody know someone at pontiac!?!?!?
Could you be more specific about the problem? Does it actually start for a second? Does it die when you put it in gear or just right after it catches? Do any lights blink on the dash? Check engine light lit? What would happen if you started it and immediately reved it - could you keep it running if you did this and held it at a high rpm?
Fixing legends is easier than fixing lolcats, but the parts are way more expensive.. New Project. Post your thoughts! http://www.acura-legend.com/vbulleti...-crazy-128859/ |
Stock Is Best
We just had a 2001 Grand Am with this problem at the dealership I work at. We couldn't fix it so we took it to the Pontiac dealer. It was the ignition cylinder, it kept losing its passcode security. $400 later and it works like a charm.
-BDE "I like your cane." <<< >>> LMAO. You had to be there. CLICK!!>>> Newbie FAQ...Read It!! <<< CLICK!! My Coupe - Sold My New Coupe |
Sherwood GS
I think it's possibly a fuel system immobilizer of some sort. Weird security feature on some GM's. My mechanic had one in the garage with a similar issue and there is some sort of procedure to reset it. I just left him a voicemail to get back to me with the procedure. IIRC you might need an OBDII scan/communicator tool.
#13 (permalink) | |
#14 (permalink) | |
i really appreciate all the help and advice! i hope to get this car running soon!!
#15 (permalink) |
burning dinosaur bones
I'd say Mastervtec is right about the passcode problem, and you'll almost certainly have to get it into the dealer to get it right. It's worth trying with a second key (if you have one and haven't tried that yet) in case the problem is with the chip on the key you're using.
I got a couple of door keys cut for my van (not chipped) and if I try to start it up with them it behaves exactly the way you describe. My van isn't a GM, but I suspect the system is pretty similar. An interesting thing I figured out for my van is that I only need to hold the chipped key near the ignition cylinder for a couple of seconds when I start and it will run just fine with the dumb key. The verification just occurs at startup I guess ... |
