| Automotive Discussion Discuss Automotive News & anything auto related. (No RL or Legend discussion!) |
tips on pumping gas
> > TIPS ON PUMPING GAS (Good information)
> > > > I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. My line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon.. > > > > Here at the Kinder Morgan Pipeline where I work in San Jose , CA, we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons. > > > > Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps > > > > When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money. > > > > One of the most important tips is to fill up when your gas tank is HALF FULL. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount. > > > > Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. > > > > Hope this will help you get the most value for your money. |
cool, thanks for the tips
The Performance Handling Sedan Ksport Coilovers, MLS strut bar, Fut's rear tie bars, ADDCO rear sway bar MAY 10TH CHARLOTTE NC LEGEND MEET! CLICK HERE Winter NC meet picture and discussion thread! |
303 Customs
"> > One of the most important tips is to fill up when your gas tank is HALF FULL. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount."
Filling up at half full also helps with your fuel pump, keeping the pump submerged in gasoline actually helps the pump stay cool and have a longer longevity. Thanks for the other Tips.
HEY COOL MAN THANKS FOR THE KNOWLEDGE
[url]http://www.myspace.com/jinxednco Car List 81 CJ7 restoring 93 Ac Legend Sedan (starting fresh headed for VIP) 93 Ac Legend Sedan (Undecided) 70 Olds Cutlass Supreme w/ the 455&turbo400trans 91 Nissan 240sx 5spd. (wifeys Whip) she wants to learn to drift? [color="Blue"][u]92 Ac Legend Coupe (Daily Driver)TypeII Intake+Injectors and rail+Throttle Body, EGR Blocked off, Venom 400, Rebuilt at 130,000 due 2 BHG, custom grille, Weapon R Intake and CAB, Factory option upgraded wheels,[/COLOR] |
[quote=Bumbi;1241044
Filling up at half full also helps with your fuel pump, keeping the pump submerged in gasoline actually helps the pump stay cool and have a longer longevity. Thanks for the other Tips.[/QUOTE] That was true a long time ago, but not today. These days fuel pump is cooled and lubricated by the fuel that goes through the pump, not the fuel that's around the pump. Many cars have pumps external to the gas tank. As long as you don't run your pump dry, you're fine. |
the brain is top notch
just drive to oregon & let them do it as they are all trained professionals (illegal to pump your own gas in oregon)
soon to come mods... *twin turbo kit running 20psi *diesel engine conversion kit so i can run on long john silver's old grease *lambo doors, yes all 4 *27,000 watt sound system *hydraulics all the way around *chameleon paint *3.2 type1 swap *soft top convertible conversion *all white cloth interior *blank cd-r hanging from my rear view mirror |
Yuka.Blue.
Found out the hard way it's illegal to pump your own gas in New Jersey too. I believe Oregon/New Jersey are the only states. Good tips =)
This is a repost from earlier this week. After much discussion and further web research it was determined that some of these tips would give minor improvements, and others may be false. Here is more info from the previous post....Fuel Mileage Improvement
'91 LS - Golden Glow Pearl Clearcoat (YR-502P) w/ Cream Ivory Leather (Type F) 92,000 miles Modifications = Sunroof Tilt, Armrest w/ Cupholder swap, tint removed, Iggee Front Seat Covers with Visable Controls Mod (see DIY below), no other mods... DIY's 1) How to Install Iggee Front Seat Covers http://www.acura-legend.com/vbulleti...8/#post1293770 2) Iggee front seat covers w/ seat controls mod . |
303 Customs
"That was true a long time ago, but not today.
These days fuel pump is cooled and lubricated by the fuel that goes through the pump, not the fuel that's around the pump. Many cars have pumps external to the gas tank. As long as you don't run your pump dry, you're fine" Not completely true, while i attended WyoTech I ran a test comparing 2 walbro 255 pumps from the g1 legends. The one that i filled up when it was 1/5 empty ran dead at almost 10,000 hours earlier
#13 (permalink) | ||||||||
Cure Hunger:Soylent Green
Deep Breath. Quote:
I'm not even remotely saying that this vapor theory is worth anything, I'm just refuting the statement and the logic. Quote:
But that means that the vapor isn't escaping unless you loosen the filler cap. Quote:
Next we'll see the "don't everybody don't buy gas one day and all the oil companies will go bankrupt." Suuuuure they will. Shell oil alone is making $75 million dollars a day in PROFIT (as of January 2008). They profited $27.5 Billion dollars last year...and that's just one oil company.
200 Degrees, that's why they call me Mister Fahrenheit. Quote:
#15 (permalink) | |
Time to go back to WyoTech. |
