| The Lounge Talk about news, life, etc!! |
I just finised up the rest of my 90k service at the local honda dealership.... They had good service....(obviously not close to an acura dealer) and good prices.....I paid 310 ..compared to other honda dealers who quoted 400.....plus acura 550....and the local mehanic 369.
Just sharing.... ![]() |
#2 (permalink) | |
Re: Had a good experience at Northwest Honda in Baltimore..
08 Smart Fortwo Cabriolet (Black w/ Red Interior) 93 Acura Legend LS 6speed coupe (Green) 90 Acura Legend LS 5speed coupe (White) |
Its Northwest Honda up in Owings Mills.. I don't know about not accepting acuras..........all the honda places I called seemed to welcome me.
listed below are two of the dealers websites... http://www.northwest-honda.com/ they are also known as the goldenruledealer... http://www.marylandhonda.net/Maryland_honda_new.htm here is a list of the maintance they did.... Replace Engine Oil & Filter Inspect Front and Rear Brakes. Check Pads end Discs for Wear (thickness) and Damage Front___ Rear___ Check Calipers for Leaks and Tightness of Mount Bolts Check Brake Shoes for Cranking, Glazing, Wear and Contamination and Service Rear Brakes Rotate Tires: Follow The Pattern Shown In The Owner's Manual - Check Tire Inflation end Condition Inspect Tic-Rod Ends, Steering Gearbox, and Boots Check Steering Linkage for Looseness Check Condition of Rack Boots Check Fluid Lines far Damage or Leaks Inspect Suspension Components Check Bolts far Tightness Check Ball Joint Boots far Deterioration and Damage Inspect MacPherson Struts Inspect Driveshaft Boots for Cracks, and Check Boot Bands for Tightness Inspect Wiper Condition Check and Adjust Clutch Install Auto Solutions Friction Modifier Check all Fluid Levels, Condition of Fluids, and Check for Leaks. If Needed, Add Engine Coolant, Brake Fluid, Power Steering Fluid, and Windshield Washer Fluid Check Parking Brake Adjustment, Should be Fully Applied Within 6 to 9 Clicks (disc brakes) 4 to 7 Clicks (drum brakes) Lubricate All Locks, Hinges and Door Seals Inspect Brake Hoses and Lines. Cheek Master Cylinder, Proportioning Control Valve, and ABS Modulator for Damage and Leakage. Balance Tires Inspect Cooling System Hoses and Connections Check for Damage, Leaks and Deterioration Check for Proper Fan Operation Inspect Exhaust System. Check Catalytic Converter Heat Shield Exhaust Pipe, and Muffler for Damage, Leaks, and Tightness Inspect Fuel Lines and Connections. Check for Leaks Check Operation of all Lights Inspect the Underbody Check all Frame and Panels for Damage. Inspect and Replace As Needed Air Conditioning Filter if the Vehicle is Driven in Urban Areas wish a High Concentration of Soot If Applicable fetter additional) Replace Air Cleaner Element Install Auto Solutions Fuel System Cleaner Degrease Engine Compartment Replace Spark Plugs (4 cylinder models)(as required) Inspect and Adjust Drive Belts Replace Transmission fluid (use Genuine Honda ATF or MTF) Repack Rear Wheel Bearings as Needed Inspect and Replace Fuel Filter as Required (replacement additional) Adjust Valves (as required) Replace Brake Fluid (as required) the maintence is split by letters..for the 90k you get the A, B, C.... (its all on the website) This was first time i was there...but alot of my friends have bought cars there and were happy....I have heard bad things about places like hersons honda so i thought people might want to know not all honda places suck. also the G1 maintence matches fine...but I am not sure the G2 does...... Mike |
Err...
did they not replace the water pump and timing belt??? errr... ?
#8 (permalink) | |
#10 (permalink) | |
plus i got all you can drink starbucks and krispee kream... ![]() |
WOW - $550 form another Acura!!!
Now that trip to Canada seem less enticing. Damn you Mike! - j/k. I think I schedule it soon. Sures beat the $800 Acura pricing for the TB /WP & $600 for the 90k thing over at Ellicott City (& this is AFTER the coupons) Thanks |
Mike-
I just scheduled an appointment w/ Rosenthal Acura for my 90k & Timing belt/WP service. Total came up to $925 w/o oil change since i do my own oil (tax included & also a loaner car). Most places I called up were charging $750 to $890 just for the TB/WP thing only! I guessed my baby needs a professional pampering once in a blue moon. Thx for the heads up on Rosenthal Mike=Da Man |
#13 (permalink) | |
94 Milano Red LS coupe 6 speed 94 Pearl White LS Sedan (sold )
#14 (permalink) | |
Also I guess they discrimnate against G1s cause I ain't get no loaner.. HAHAHA |
#15 (permalink) |
YEah thx - that price I was quoted is after coupons ($1060ish before).
Not bias against G1 cause my G2 TB/WP is $540 after discount (wasn't your's $500ish?). I'm crossing my finger that all they have for a loaner is a NSX! Oh well - guessed I'll be looking for that ramen noodle thread recipete for the next 6 months or so... ![]() |
