Son of the Most High
2nd Gen OEM Struts & Springs - Need Help
I believe that I popped my drivers side strut - a lot of rattling over simple bumps and front end up/down travel. I had gabriels on, but am wondering if they were good enough for NYC streets. I dont want to lower or raise my car. All i want to do it try to restore (as close as possible) the original ride and height of my car.
I have done a search, but all i keep coming up with is eibach this and koni that, lower this and camber that. 1. Who makes/where can I get, the OEM brand for the 2nd Gen Legend Sedan (non GS)? 2. Who makes/where can I get the OEM brand Springs for a 2nd Gen Sedan (non GS) Peace, Thanks
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." R-Swift, Revolutionary Theme Muzik "Out the dark since the Light sparked when its splittin curtains. Now I live curseless, no longer worthless. Still grippin the mic, but now I just switch purpose."
You might have a broken spring. I had a rattle in my drivers side for like three years and couldn't find it until I replaced the struts and found that the top of that spring was broke right under top cap that holds the insulater in place. I recently replaced all my corners with gabriels and also I ended up getting two new front oem springs.
I still have the original passenger side spring and strut around the garage, minus all the rubber and plastic hardware that holds the strut/shock together. PM me if your interested........ |
#4 (permalink) | |
You know, might be springs - I put these gabriels on in the summer, so I cant imagine them breaking so easy, but anything is possible in NYC. I was trying to hold off until later in 2007, but it seems I have to replace all my corner hardware - springs and struts - who makes OEM springs? I will probably go back to the Gabriels, but if I need springs, where do it get them beside the dealer?
T The pimp
driving in NYC parkway is a good time to test your suppension system. like alot of bumby or noise making when went over a bumb. or the rear car getting throw off. My bro just did his rear sway bar bushing and strut whew 65-75 mph in FDR drive is nothing but I had notice the front start to get alittle bumby since the rear supession is completely soilid. After the replacement we notice a huge improvement over cornering handling.
#6 (permalink) | |
Kia Killa
Hey boss, I wanted to remind you to check your front upper control arms. You moght be suprised, but they affect the performance of the suspension BIG TIME. I had put a set of 4 KYB GR2 shocks on my sedan a few years back and was disapointed with the results - still had lots of noise over bumps, squeeking, etc. I threw a set of upper control arms on and it drove like new! I never even needed struts. I always manage to learn the expensive way.
-Matt
my bad, I didn't realize you were mentioning its your drivers' side.
I would say that the mine would have more of a metal grinding sound when I would go slow up over speed bumps and making right turns. The sound eventually went away over time. Its when I put on new 18" wheels and went through an uneven street intersection at a decent speed, I notice the wheel wheel on the drivers front bottomed out and slightly bent the fender well I realized the spring or strut might be the problem. Some of the Philly streets are bad, but so far the new oem springs and gabriels are holding up like champs. You can't get oem type springs at regular auto parts stores. You can only get oem springs through a dealer. I get all my oem parts online through Delray Acura: http://www.acuraoemparts.com/delray/jsp/home.jsp descent dealer prices and never had a problem looking for what I needed. |
#8 (permalink) | ||
I am gonna take a look tomorrow and see before I go to my mech. Ultimately, what I wnat to do is just get 4 new oem springs and a set of gabriels and call it a day Quote:
#9 (permalink) | ||
Kia Killa
The only really good way to check the upper control arm would be to pop the upper balljoint off. You can then check the condition of the inner bushings for wear and the balljoint for play. Speaking of bushings have your mechanic check the front-most control arm bushing, they are prone to breakage. -Matt
#10 (permalink) | |
I guess I have to let my mech look at it.
| Eibach's on oem struts that were replaced 2 years ago? | inthavillelegend | Second Generation Legend (1991-1995) | 2 | 05-17-05 10:06 PM |
| FS: OEM springs off 94 GS | bobert486 | OEM Parts | 0 | 05-16-05 01:51 AM |
| Squeaky Springs or Struts | Michael C | Second Generation Legend (1991-1995) | 1 | 01-21-05 05:04 PM |
| ntb struts 2nd gen | chad | Aftermarket Parts | 0 | 08-16-04 05:43 PM |
| OEM 2nd Gen Sedan Leather | DaRK RaIN | OEM Parts | 16 | 08-14-04 10:43 PM |
