Numerous things can cause brake fluid loss. Brake lines, caliper piston, master cylinder and as mentioned the booster. The only thing you can do is trouble shoot.
Clean all areas with degreaser, look for signs of brake fluid. If you can't see where the fluid is going more than likely the booster is where it's hiding.
