originator of " GNAR "
creaking front end suspension
yeah.. i dont know if you know what i mean, but..simply. my front end is creaking and squeaking..shot shocks?
if i change it up, should i change both ends? drop it? what brands work? ive never dealt with suspension -_-
92 Legend LS silverstars Injen Short Ram smoked |
Could be bushing related. Check front sway bar bushings to start.
If you're sensitive over the internet, consider suicide, because real life tends to be worse. Opinons are like assholes, there's always one whereever you go! A newly formed forum/car club that is open to any car enthusiast. http://redlinesoldiers.forumotion.com/index.htm |
i had the same issue with my 95 sedan.
the creaking noise was coming from the passenger side, it would creak loud enough when i make a turn and hit bumps. i found out that the inner joint's boot was completely torn. i pulled the entire axle and re-pack the inner joint with new high pressure grease and new inner boot. i also re-packed the outer joint with new high pressure grease and replaced the outer boot with new one. i thought it was the rubbers, shocks, tie rod ends, ball joints...etc, but none of them. it's been nearly two months now and it's creak free.
| Creaking noise from front end | Mark5 | Second Generation Legend (1991-1995) | 14 | 12-16-06 12:30 AM |
| New front suspension | Herb | Second Generation Legend (1991-1995) | 2 | 11-20-05 06:16 PM |
| Squeaky/Creaking Suspension FYI | txlegend | Second Generation Legend (1991-1995) | 0 | 07-09-05 05:59 AM |
| "CREAKING" noise... suspension component needs replacement? | theGodfather | Second Generation Legend (1991-1995) | 13 | 10-24-03 02:52 AM |
| Suspension creaking? | legend4life | Second Generation Legend (1991-1995) | 8 | 09-30-02 10:35 AM |
