Old 11-13-07, 03:15 AM   #1 (permalink)
originator of " GNAR "
iPushLS's Avatar
Car 1: 1987 Toyota Cressida.sold =[
Car 2: 1992 Acura Legend
Car 3: 1974 Porsche 914-4
creaking front end suspension
yeah.. i dont know if you know what i mean, but..simply. my front end is creaking and squeaking..shot shocks?
if i change it up, should i change both ends? drop it?
what brands work?
ive never dealt with suspension -_-
92 Legend LS
silverstars
Injen Short Ram
smoked
iPushLS is offline
Old 11-21-07, 02:03 PM   #2 (permalink)
Car 1: 1992 Acura Legend sedan
Send a message via AIM to david7700 Send a message via Yahoo to david7700
My Legend has the same issue. New OEM shocks are what I'll get eventually... I don't want a stiffer/firmer ride.. despite the obvious benefits to performance that would have.
Legend .. what!
david7700 is offline
Old 11-21-07, 02:09 PM   #3 (permalink)
NYCOWNSU's Avatar
Car 1: It's gold had one stripe and says metro on it!!
Could be bushing related. Check front sway bar bushings to start.
If you're sensitive over the internet, consider suicide, because real life tends to be worse.
Opinons are like assholes, there's always one whereever you go!
A newly formed forum/car club that is open to any car enthusiast.
http://redlinesoldiers.forumotion.com/index.htm
NYCOWNSU is offline
Old 11-21-07, 08:52 PM   #4 (permalink)
MagicMikey's Avatar
Car 1: '91 LS Sedan
Send a message via MSN to MagicMikey
Turned out to be all 4 ball joints for me... usually dries out then corrodes making a creaking noise. Easy to check for play yourself.
1991 Acura Legend LS Sedan
Granada Black
MagicMikey is offline
Old 11-21-07, 08:56 PM   #5 (permalink)
legendfire's Avatar
Car 1: 1994 6spd coupe
Send a message via AIM to legendfire Send a message via Yahoo to legendfire
its the front tied rods. most likely the inner ones, or atleast it sounds like it.
legendfire is offline
Old 11-22-07, 02:49 AM   #6 (permalink)
13 Years and Still Strong
93/95Coupe's Avatar
Car 1: 93 Taffeta Coupe
Car 2: 97 Camry
Listen, if its creaking while you brake and go around a turn of something like that, lube your caliper pins, don't spend all the money on control arms, etc..
93/95Coupe is offline
Old 11-22-07, 03:37 AM   #7 (permalink)
astigracing's Avatar
Car 1: 1995 Acura Legend Sedan L
Car 2: 2000 BMW 528i
Car 3: 1998 Toyota Rav4 L
Send a message via Yahoo to astigracing
i had the same issue with my 95 sedan.
the creaking noise was coming from the passenger side, it would creak loud enough when i make a turn and hit bumps. i found out that the inner joint's boot was completely torn. i pulled the entire axle and re-pack the inner joint with new high pressure grease and new inner boot. i also re-packed the outer joint with new high pressure grease and replaced the outer boot with new one.
i thought it was the rubbers, shocks, tie rod ends, ball joints...etc, but none of them.
it's been nearly two months now and it's creak free.
Visit My Website
'95 Legend L
'00 BMW 528i
'98 Rav 4L
'05 Nissan Murano SE
astigracing is offline
Old 04-20-08, 08:10 PM   #8 (permalink)
Car 1: 94 acura legend ls
did they cost alot
wood is offline
Creaking noise from front end Mark5 Second Generation Legend (1991-1995) 14 12-16-06 12:30 AM
New front suspension Herb Second Generation Legend (1991-1995) 2 11-20-05 06:16 PM
Squeaky/Creaking Suspension FYI txlegend Second Generation Legend (1991-1995) 0 07-09-05 05:59 AM
"CREAKING" noise... suspension component needs replacement? theGodfather Second Generation Legend (1991-1995) 13 10-24-03 02:52 AM
Suspension creaking? legend4life Second Generation Legend (1991-1995) 8 09-30-02 10:35 AM
