#16 (permalink) |
yeah, only the tein flex are compatible with the EDFC. I guess you could buy the flexes and sell the upper mounts to someone with the TSX basic kit.
Well, next weekend I'm going to inspect the suspension components to see if there is any obvious wear going on. I'll try to grab more shot of the setup for you guys.
#17 (permalink) |
Good job Ken! I only have couple of things to clarify about the setup though:1) How are you re-routing the brake lines...is the bracket tossed away? 2) Do you have pictures of the tein pillow ball mount? Like to see if it can be modified to fit our legends. Worse case senario is the coil not properly seated within the legend's stock upper mount(inducing angular pressure to the shock's piston if the coil becomes crooked over time from sliding around the rubber perch.) The noise you're hearing I suspect is either from the fork diameter bigger than the lower shock diameter or the upper control arm hitting the fender(assuming no camber kit was installed) |
#18 (permalink) | |
2) I didnt get the upper pillow ball mounts cause I bought the basic kit. The upper mounts have 5 bolt points, 3 for the mounts and 2 for the upper strut bar. I was planning on buying the tsx oem upper mounts but decided to just use the stock uppers. If I can get one cheap, Ill buy it and see if there is anything that can be done to modify them.
#20 (permalink) | |
#21 (permalink) |
In Cabo
The question that pops into my mind is whether or not other Acura Tein's besides the TSX would work. Wouldnt you say the legend is heavier than the TSX? Could that end up blowing the Tein's prematurly?
The SS and Flex both are compatible with the EDFC ~TRu Hybrid
#22 (permalink) | |
Dont Catch
not the SS for the TSX though |
#24 (permalink) | |
I'm pretty sure that the newer tl teins would fit, probably better than the tsx but i cant say for sure.
#26 (permalink) | |
WHAAAAAH!
Thanks for helping the blind, old guy see the link ![]()
#27 (permalink) |
Good write up. Wish you would have done it sooner....j/k...lol. I ended up going with the Eibach ground controls with stock replacement shocks.
http://memimage.cardomain.net/member.../2128031_2.jpg Damian '92 Legend....Current ride. '85 GSL-SE....(with a few goodies... )'91 RX7....SOLD... Cartek Tuning (954) 474-5366 Dyno-Jet facility In house tuning available for... SAFC E-manage Haltech AEM (Factory Trained) Power FC And other various systems. |
#28 (permalink) |
Hi
Bump...how are these shocks holding up?
I would love to do this. The Tein kit is cheaper than the Koni Sport kit and seems to be much nicer. So with the 98-02 Accord forks and washers in the rear, this all just bolt up? Then the only concern is with the extra 200-300 lbs that the Legend weighs. I wonder how the TL shocks differ from the TSXes, because they would probably be a better bet. Last edited by Herb : 04-30-06 at 10:49 AM. |
#29 (permalink) | |
| how many legends? | ndhduong | Second Generation Legend (1991-1995) | 42 | 08-24-08 10:30 PM |
| New Legend Owner...lots to say/ask | ALoneR | Second Generation Legend (1991-1995) | 28 | 10-30-06 01:45 AM |
| 91 Couple L auto clean title $2000.00 | Vintagecarman | Legend | 2 | 12-01-05 07:49 PM |
| Legend vs. kitted out Legend vs. riced out Civic | ThaAcStangSwerver | Track Racing | 7 | 09-06-02 06:51 PM |
| Guess who's back in the Legend Family??? | SammyD | Second Generation Legend (1991-1995) | ||
