#1 (permalink) | ||
33mpg 6spd Coupe
The Great Wheels vs. Offset vs. Fender alignment thread
I think having a thread like this will go a long way towards limiting the number of "will this wheel fit" topics.
Please post a reply with your stats, in the following format. Quote:
I have stock LS wheels on my 1995 Legend LS Coupe, they are 6.5 inches wide, with +65 offset, and they are inside of my fenders.
werd.....
I have 18" 5Zigen Super Six wheels on my 1992 Legend LS Coupe, they are 7.5" wide, with a +48 offset. They fit inside the fenders all the way around.
I use 225/40-18 Khumo Ecsta tires Last edited by RangerJoe : 11-05-07 at 11:11 PM. |
good idea I think we should also include if the car is lowered and by how much.
I have a typeII coupe 18x8 +50 (just put em on saturday) 235 40 18 lowered w/ ksport about 1.75 or 2 inches. Front are pretty much ok might hit the inner linning when the wheel is locked. The rear rubs a little bit it's very close to clearing, but I think I will roll my fenders. I also had a set of 17x8 +55 w/215 45 17 lowered with eibachs and konis on my old typeII coupe and they were a perfect fit no rub ever. |
It's stock, really.
I have OEM Acura NA1 NSX wheels on my 2nd-gen Legend sedan. The wheels were from an early (91-93) NSX.
In front they are 8-inches wide, with +60 offset, and they are flush with my front fenders. In the rear they are 6.5-inches wide, with +55 offset, and they just inside my rear fenders. They are, however, about an inch closer to being flush than the factory Legend rims.
dealer-opted track pack
I have Ro_Ja/R2-5 (manufactured by Ray's Engineering) rims on my car. They are 8" wide with +47 offset, and sit inside my fenders by a millimeter or two.
I am dropped almost 3" with a track alignment (at least 1.75 degrees camber all around, toe in on the rear) and rolled fenders. I currently have BFGoodrich g-Force KDW2 tires @ 225/40/18. Disclaimer: this setup is un-drivable without heavy suspension modifications, as the car would rub and bottom out. If I corrected the camber, these rims would sit flush in the front, and probably stick outside the rear fenders on my coupe. werd.
The performance handling machine... ![]() If you've got coil-overs, corner-balance them! Please protect our environment: use a high-flow. Last edited by mrkeith : 11-07-07 at 05:35 PM. |
Chicken & Dumplins
I have Legend Wheels. They are 18X7.5 +38mm offset 225/40/18
They are flushed but very close, so I cut the rear wheel well lip out after I lowered the car. where did you get 48 series tires ![]()
Click for Deep Discounts http://4450488.shopwize.com FS/Trade: JDM KA7 Headlights & Door Switch, heated seat switch 91-95 Sedan fender,3.5 RL HEADS , INTAKE MANIFOLD & FUEL RAILS , http://www.acura-legend.com/vbulleti...htside-124468/ http://www.acura-legend.com/vbulleti...ad.php?t=95844 |
#9 (permalink) | |
33mpg 6spd Coupe
I'm pretty sure I picked out a wheel I like well enough to buy. Forged, 17x8, +45 and just over 14 pounds. I'm thinking I can slap 235/45/17s on them.
From what I understand, this is the same size as the TL rims many forum members have tried. I'll edit this post with fitment info when I get them. edit #1: yes, TL wheels are the same - http://tl.acurazine.com/forums/showthread.php?t=117535
#10 (permalink) | |
99 RL
Lowered about 2.5 inches Fr 18x8 +35 215/40/18 Rr 18x9 +35 225/40/18 Fairly flush with fenders. Small amount or rubbing in the rear only and fenders are not rolled. *Update* Fenders have been rolled and all rubbing is gone. Last edited by SdotCamp : 12-30-07 at 05:12 PM. |
#14 (permalink) |
B.K.A Runa
well question will a 8.5 wide 20 inch wheel with 40mm offset fit without rubbing. Or if i roll the fenders will they fit right
I also wish I had caught a knee cap with him facing me, just to send a message to faggot ass theives that like 2 steal. "NO EASY TARGET HERE. ATTEMPT THEFT AT UR OWN WAGER, BUT WHEN THE HOUSE WINS U MAY LOSE MORE THAN UR CHIPS. i.e. UR LIFE." G2BMC |
| The "I got a great deal' thread | TonyTheBullet | The Lounge | 37 | 07-02-07 05:43 AM |
| umm i need the offset on my wheels. | 93gold_legend | Wheels, Tires, Brakes, and Suspension | 12 | 02-28-07 01:51 PM |
| what size offset of wheels fit 18" wheels | Hey its Antman | Second Generation Legend (1991-1995) | 29 | 08-05-04 10:19 PM |
| is the offset for all 4 wheels 50? | Atiyeh | Second Generation Legend (1991-1995) | 2 | 08-29-02 12:36 AM |
