Old 04-02-07, 11:04 AM   #1 (permalink)
Call me Mister
G Rahn's Avatar
Car 1: 94 LS sedan
K-Sport spring rates
I am preparing to order a set of K-Sport coilovers and I am trying to determine what spring rate to specify. I read on the group buy page of 12/7 and 13/7 rates, but I have no idea what that relates to. Apparently, I can custom order any rate from K-Sport, and I want something that isn't going to bone-jarringly harsh. The Eibachs are stiff enough for my liking.
I am not going to be lowering the car radically if that is an issue. I like the drop I have with my Eibachs, which is about 1 1/4" as I recall.
So, how do spring rate numbers work? Is there a way to compare stock vs Eibach, for example?
~ Guy
URL=http://imageshack.us]<a href=http://img69.imageshack.us/img69/1095/wallpaperyb6.jpg target=_blank>http://img69.imageshack.us/img69/1095/wallpaperyb6.jpg</a>[/url]
G Rahn is offline
Old 04-02-07, 11:50 AM   #2 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
well, first of all, tahts gay that you can pick your own rates and when i ordered mine i was told it wasn't possible.
as for the spring rates thenselfs. ksports are 13/7, thats stiff. cared to ground control with a 4/3 or 6/3(4) something like that. if u want soft ride, i'd do around that, i think the eibach prokit are softer then that maybe 3/2ish.
i think in the original Ksport thread we had all of them listed. try reading up in that thread.
~Alex
94 GS
Alperovich is offline
Old 04-02-07, 12:00 PM   #3 (permalink)
Bitter Old Man
Car 1: 1990 Legend LS sedan
Car 2: 2002 Dakota SLT QC
Car 3: 1998 Bandit 1200S
If I read the K-sport web site correctly, those are metric numbers. 13 would be rate in kg/mm; converting to American units yields 728 lb/in. Rather stiff unless the spring sits way inboard.
Conversion factor is 56, give or take a fraction. I don't know what 7 indicates...maybe wire thickness?
Bruce in Houston
2007 Mazda MX-5 Touring
2002 Dodge Dakota QC tow beast, stock!
1998 Suzuki Bandit 1200S w/ $tuff
1994 Nissan Sentra SE-R w/ $tuff converting to ITA
1990 Acura Legend LS sedan leaving the stable
slartibartfast is offline
Old 04-02-07, 12:06 PM   #4 (permalink)
Blackend Motorsports
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
Ksport will recomend not changing the spring rate because the damper settings are valved to work with the preset spring rates and changing that may result in damper failure.
I have my dampers set to full soft and it is still WAY stiffer than the Koni/H&R set up I was on. If you're looking for adjustability, but you're not auto-x or tracking your car, I would say go with some GC threaded springs.
As a daily driver - Ksport is not the way to go.
NALM NAZI
We Brought Them
We Broke Them
We WILL Rebuild Them Better!
Blackend is offline
Old 04-02-07, 12:53 PM   #5 (permalink)
lgnd4u2nv's Avatar
Car 1: 1991 Acura Legend
Send a message via AIM to lgnd4u2nv
you say the eibachs are stiff enough for your liking.....and you dont plan on lowering you car more than it is......
so maybe im missing something. why do you want the Ksports?
they are only gonna make your ride stiffer and give you the ability to lower your car more
MAY 10TH CHARLOTTE NC LEGEND MEET! CLICK HERE
Winter NC meet picture and discussion thread!
lgnd4u2nv is offline
Old 04-02-07, 01:25 PM   #6 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
the 13 is the front spring rates, 7 is the rear.
i agree, koni's with eibach's is probably more of what he is looking for....
~Alex
94 GS
Old 04-02-07, 01:30 PM   #7 (permalink)
Call me Mister
G Rahn's Avatar
Car 1: 94 LS sedan
I see the coilover system as being superior to what I have now- they are easy to adjust to the exact height I choose, and I like the individual adjustments so I can overcome the "driver sag" that is common with the separate coil and strut setup. I wouldn't mind some extra stiffness- just not to the degree Blackend and others have.
I understand your point on the potential for valve failure due to excessive spring travel, Blackend. I'm going to try to find a liveable compromise between shortened service life and kidney replacement surgery.
I'll dig through the spring rate threads and see if I can decipher it- from what I can gather, the lower the number, the softer the spring, correct? Perhaps a 10/7 would be a good choice here.
~ Guy
G Rahn is offline
Old 04-02-07, 02:02 PM   #8 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
yea softer spring rate the lower the number. I'd call up Ksport and find out whats the softest spring rates you can order.
~Alex
94 GS
Old 04-02-07, 03:10 PM   #9 (permalink)
Blackend's Avatar
I'm not sure Ksports are the right decision though. For what you'd spend on them to gain adjustability, you could save yourself several hundreds of dollars and buy a set of Ground Control springs. Very similar rates to the Eibach setup, but they're fully threaded sleeves so the height adjustment you want is there, but without the need for Ksport to match the valving on their dampers (read CUSTOM WORK $$$) to the spring rates you want.
Last time I checked, you can still get GC's for around $400 brand new and there are sets to be had used for around $200.
NALM NAZI
We Brought Them
We Broke Them
Blackend is offline
Old 04-02-07, 04:09 PM   #10 (permalink)
Car 1: 1993 sedan
just use the ksports the way they are .... in my opinion its not harsh at all.
93 Sedan 5spd
Type 2 Manifold
Bayou Chip
CL-S wheels
4300K HIDS
Ksport Coilovers
Alpine cda-9831
TheLegend5peed is offline
Old 12-29-07, 10:10 PM   #11 (permalink)
Registered Libertarian
jkurl's Avatar
Car 1: 95L sedan grn
Car 2: 94LS 6spd cpe grn
Car 3: 67econoline 63nova
G Rahn, did you ever sort this ksport spring rate question out? I'm itching for ksports but not lots of bouncing or rattling, the roads in los angeles are horrible. thanks
jkurl is offline
NOPI-XBOX Honda & Acura Nationals - St Louis - July 23/24 NOPIMAN Meets 3 05-08-05 04:00 AM
what are the SPRING RATES??? Volk Racing Second Generation Legend (1991-1995) 14 03-04-05 05:24 AM
Can someone post spring rates for Stock,Eibach sport, GC Roger Second Generation Legend (1991-1995) 2 12-13-04 01:55 PM
Ground Control Spring Rates KTD Second Generation Legend (1991-1995) 1 09-12-04 08:53 PM
Sport springs need spring compressor? Volk Racing Second Generation Legend (1991-1995) 5 01-17-04 04:08 AM
