#31 (permalink) |
werd.....
if you have 18x7.5's at least a +45 offset would be recommended. sedans have different wheel wells than coupes, so if you have a sedan, try to get a higher offset if possible.
i know voxx, konig, 5zigen, racing hart, they all sell high offset wheels in these sizes. (voxx does a +50 offset with an 18x8) for a 7.5 wheel, a 225 tire works, and looks cooler, but businesses will recommend a 215 width tire...either one will work...225 width is just alot more common |
#32 (permalink) | |
K L E A N M O D™
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
#33 (permalink) |
These are the rims i am having, The rubbing on the wheels are very intense on the rears, not so much on the front. What other options is available to stop the rubbing? Also i do not plan on dropping the car at all, just getting new eibach springs, and koni shocks. all around. HEre are the mods of the rims currently on the g2 Axis Spider 18's! Let me know if anyon can help me tuck in the front wheels there popping out likes it hot. |
#34 (permalink) | |
K L E A N M O D™
#35 (permalink) |
Anyone in the market for 18's, here's a set for a bargain price.
http://www.v6performance.net/forums/...ad.php?t=44037 Should fit perfectly...
_____________________ mark@highsocietyVIP.com http://i16.photobucket.com/albums/b1...g?t=1164987466 |
#36 (permalink) |
What do you mean rotate them? and in which circular motion? which pattern?
#37 (permalink) | |
http://img.photobucket.com/albums/v5...8/WaldW221.jpg |
#38 (permalink) | |
I think he means to rotate the fronts to the rear and the rears to the front. This way you increase the life span of the tires. I recommends doing this at the 15k to 16k mark which equates to a year for most. |
#39 (permalink) |
I DONT GET IT, WHAT EXACTLY IS OFFSET?? WHATS A HUB BORE?? ARE YOU TALKING ABOUT DISTANCE UP AND DOWN OR LEFT AND RIGHT?? ALSO, YOU SAID IF YOU HAVE 18 X 7.5 WHEELS HAVE AN ATLEAST 42 OFFSET , AND THAT A HIGHER OFFSET IS BETTER RIGHT? SO WHY WOULD YOU GET 18 X 7.5 WHEELS WITH A 45 OFFSET IN THE FRONT AND 18 X 8 WITH A 42 OFFSET IN THE BACK?? THE WIDER THE TIRES, THEN SHOULDNT THEY HAVE A HIGHER OFFSET??? FOR EXAMPLE THE 18 X 8'S SHOULD HAVA HIGHER OFFSET THAN THE 18X7.5'S? I HAVE A 95 COUPE AND I WANTD TO HAVE EITHER 18'S OR 19'S.
