NEED YOUR HELP
i have a 92 legend 4 door. my rear driver side is lower than the rear passenger side. is it possible to have the springs backwards or is there a damage part. i dont know whats wrong but everytime i jack up my car it goes to normal then when i drive it goes back down. it looks like i have lower springs on one side of my car when in reality i dont. Please someone help me and give me some ideas on what can it be causing this. thank you.
Power folding mirrors Moonroof tilt 12000K hid with black housing and angel eyes 20% tints all around JDM window visors TL Type S rims New Interior Dual Piston Calipers |
Sherwood GS
Sounds like the shock (strut) is bad rather than the spring. Use a flashlight, take off the rear tires and make sure the two look the same on both sides (ie same combo of shocks/springs). I don't think it's the springs because you said it goes to normal ride height for a little bit after you jack it up, and then goes down when you drive, which sounds like a bad/leaking/can't hold up the weight problem with the strut....
Blackend Motorsports
Aftermarket suspension or OEM?
NALM NAZI We Brought Them We Broke Them We WILL Rebuild Them Better! G2 Legend Engine Dampers NOW IN STOCK! Click Here! |
aftermarket kyb-g2 i have on my car now
may have a spring perch installed upside down (a very easy/common mistake)
as others have said, take off the wheels and inspect the suspension from top to bottom and make sure everything is installed the same on each side.
ok thanks guys i will try this today and see what i come out with. i will keep you guys posted. Thanks again
