negro es bueno
I just got my Koni Suspension Kit from shox.com (thanks Arthur).
It's seems a lot are going with lowest perch front and middle rear. Will this work if I want to keep the Stock Stance (rear a bit higher)? Suggestions or pics of this kit with 18's would be appreciated!
JDM Type I Telion TI Chip MLS Copy Bar Koni Suspension Kit 5zigen Super-6 18x7.5 +48 - For Sale - G2 Sedan Floormats (grey) |
its a lot lower than you might think. if you are looking for a close to stock ride go with the higher perch up from and middle in rear (thats how it comes out of the box?) but if youu do go low all around get a good camber kit front and rear or be prepared to go through some tires
94 l gold 6 spd -Ranger Joe CAI -obx headers -polished intake manifold -Bayou stage II -FUT's lower tie bar brace -Magnaflow exhaust -MLS strut bar -5spd clutch and flywheel -Ksport coilovers -Addco rear sway -17" Arospeed rs-gt 94 l sedan 5spd.(totaled) |
#5 (permalink) | |
who makes a camber kit for our cars ? |
i think google does. actually i cant remember the name off the top of my mind. tire-rack sells them, but i'm sure you can find them cheaper than there.
#8 (permalink) | |
I'm the Stig!
~Alex \ |
Blackend Motorsports
Don't the sport kit springs have a 1.1 inch drop too though? With lowest perch settings on the shocks and those sport kit springs, you'll need to get a camber kit up front. Go with the SPC Ball Joint kit and I would suggest finding a Firestone close by and purchasing their lifetime allignment if you can find it for under $200. I've used mine like 4 times in the year that I've bought it...just for piece of mind!
NALM NAZI We Brought Them We Broke Them We WILL Rebuild Them Better! G2 Legend Engine Dampers NOW IN STOCK! Click Here! |
#10 (permalink) | |
I'm the Stig!
~Alex \ |
#11 (permalink) | |
You're rockin the LS/GS rims right?
#12 (permalink) | |
I'm the Stig!
~Alex \ |
brian i am slammed in the front on my 40 offset rims without camber adjusted and did not see wear. the only wear was in back because of my toe..
I adjusted the toe in front to zero and the toe in rear i can't at this moment. Ps- feels waaaay better. |
#14 (permalink) |
no koni kit is 1.1" on the highest setting its 2"+ on the lowest (especially when the springs break in" i went through a set of tires about every 7,500 miles. the rears seemed to wear faster. if you want to save some money and not get a camber kit go for it. i was at around 3 degrees of negative in the front and 1.75 degree in the rear at the lowest all around. I would say if you are not gonna track your car there is no need to have all that negative camber.
#15 (permalink) |
negro es bueno
so sounds like installing the kit out of the box (highest front/middle rear) will be close to oem stance and no need for camber kits...I like the sounds of that.
But will it be enough drop? Anyone got pics with this setting?
| Wilwood Brake Kit Group Buy | mrkeith | Group Buys | 69 | 03-24-08 01:57 PM |
| Coupe with Koni Suspension Kit : picture requested! | LV_legend | Second Generation Legend (1991-1995) | 19 | 05-08-06 11:48 PM |
| HID kit install question | BB2 | Second Generation Legend (1991-1995) | 0 | 07-30-05 10:46 PM |
| Suspension help....Koni kit installed | sunny76g | Second Generation Legend (1991-1995) | 15 | 07-26-05 10:56 PM |
| newbie body kit question | Darkstar | Second Generation Legend (1991-1995) | 5 | 04-22-02 06:52 PM |
