RSR springs vs H&R springs vs eibach springs
i jus wanted some idea on these springs. i need all the info on these springs. what are go for the smooth ride but have the racing edges. so please help me. thank.
JIC's cost an arm and a leg. Not everyone can afford them.
As for RSR's not very many people have them for the Legend. But based on other cars there seems to be mixed reviews. A lot of the complaints i've seen are they drop cars more than advertised or they're too stiff. Eibach's give a suttle drop where as H&R's give a bit more aggressive drop. Seems like H&R would suit you better based on your description of what you're looking for.
doin it since 99
I love my H&Rs.had them on since 2000 and still ride good.
Matt Garvey http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg http://www.alternativemotorsports.com |
I've got Konis and H&Rs and while i like the level of drop (lookwise), the frontend rides really hard. Every decent bump shakes the car and jars the dash. It is as if I really have no front suspension at all. I'm running an Ingalls camber kit and have and have "shaved" the upper control arm ends down a little but have only been able to solve the issue of the arms rattling against my inner fenders for a limited time. People question whether it is safe to ride in my car because it sounds like the front suspension is going to fall out.
Anyone else have this issue? I'm really sick of the banging around and crappy shock absoption up front but I hate how high stock Legends ride. I'm seriously thinking of swapping out for Eibachs, they just aren't a very aggressive drop though. Anyone else with this setup been battling this issue? I welcome your comments and suggestions. Thanks |
BTW - springs are on top perch (f) and middle perch (r). Yes I always check and have had my mechanic check upper/lower ball joint, tie rods, etc. when its on a lift and all is fine. I dod that my bumpstops have disintegrated but that should only have an effect on preventing bottoming out.
When I stomp on it on the highway I seem to feel the front slightly raise up (suspensiowise) which I seem to remember it use to be alot more stiff when I first put the suspension on a couple years ago. I originally had the shocks on full soft but adjusted them up about 1/4 turn about 6 months ago. It was a little more responsive and slightly bouncy or quick to recover (rebound) at first but now I swear they feel more soft again. Koni is telling me thats normal. I just want to fix this -- im sick of a crappy, rattling ride. Thanks. |
doin it since 99
Why do you need the camber kit?I have mine aligned every 6 months when shes running properly and use h&r springs w/oem shocks,if your konis are on the top perch and the arms are all straight you should not need the camber kit.At the shop we had to use an ingalls kit on one with konis and eibach on the lowest perch but the car had hit a curb,still no shaving of anything or rattling.I don't think your problem is the springs.Did you cut the bumpstops in half?Check to make sure everything is tight and all the bushings are in place andnot worn out.
I've never heard of anyone not using a kit with H&Rs and not experiencing some uneven wear-- Ive heard you don't need one with Eibachs. I rode without a camber kit for a few -- 6 months and it started wearing my inner treadblocks. I dislike the Ingalls kit - always got to regrease it because it squeaks and my car sounds like a carriage.
As far I know and anyone can tell me, nothing is obviously worn on my car -bushing wise. As mentioned before, my bumpstops are non existent - they disintegrated. Also, when I back up out of a parking spot and turn the wheel, a loud pop will come from the front like the arms are rubbing and popping off the inner fenders. Are you telling me that your car rides good with H&Rs and stock shocks? And you have no rattling issues. Does your car take bumps (potholes, changes in elevation of concrete slabs greater than 3/4 inch) smoothly? If so, WTF is wrong with my car. It is seriously driving me insane. Thanks. |
#14 (permalink) |
doin it since 99
Yes it rides good-no rattling issues at all.As for smooth I gave that up with 215/35/19 tires,also I have removed the inner fender wells[plastic parts].
#15 (permalink) |
I have Eibachs and Koni reds with 215/35/19s on my coupe. I can't complain about the feel b/c of the tires, but the suspension setup is great. I have no idea if they are on soft or hardest setting (I have nothing to compare it to as the shop put them on and I drove away- thats it).
I can say that it is barely noticeable of a drop. These 19s raised the car a tiny bit and now I can pull forward into parking spaces pretty much all the way until it hits my tires, no rubbing unless its a huge block. But with that drop and stock tires, I would barely scrape the block everytime. Wish I had gone with H&Rs. If anyone with H&Rs would rather have Eibachs, email me and we'll switch. magicdragon3@hotmail.com Kevin |
| Feeler: Free Eibach springs (w/ a catch) in So. Cal. | Osamu | Aftermarket Parts | 9 | 11-29-06 02:55 AM |
| Difference between Front & Rear Eibach Springs? | ihookituuup | Second Generation Legend (1991-1995) | 3 | 06-27-04 08:21 PM |
| FS: Eibach Pro-Kit Springs 91-95 G2 Cpe/Sdn | Thai.95LCoupe | OEM Parts | 16 | 03-24-04 03:09 AM |
| Ground control, eibach, or H&R | RangerJoe | Engine & Performance Modifications | 21 | 09-29-03 04:22 PM |
| Eibach Springs For Sale | F666 | OEM Parts | 0 | 04-27-03 05:29 AM |
