Old 02-01-07, 03:26 PM   #1 (permalink)
chapman89's Avatar
Car 1: 1993 Acura Legend LS
Springs and shocks, When to replace?
I'm not sure, but is there any certain time when you replace the shocks and springs? As of now I have close to 170K and the car seems to drive fine, no excessice bouncing after hitting bumps or anything like that. I'm sure the stock ones aren't as stiff as they used to be, any input?
thanks,
-nick-
New pictures of my 93' LS sedan
WTB: Type F, Drivers door weather stripping! PM me!
FS: OEM 15in Legend Wheels. Great condition! PM me!
chapman89 is offline
Old 02-01-07, 03:51 PM   #2 (permalink)
Chicken & Dumplins
whyteLegend's Avatar
when they break, sang or when you fell like. Mine leaked before they got changed.
Click for Deep Discounts
http://4450488.shopwize.com
http://www.acura-legend.com/vbulleti...htside-124468/
http://www.acura-legend.com/vbulleti...ad.php?t=95844
whyteLegend is online now
Old 02-01-07, 04:39 PM   #3 (permalink)
awelliott's Avatar
Car 1: 1987 Legend L Coupe
Car 2: 03 Honda Odyssey EX
Car 3: 93 Dodge Dakota LS
thanks,
-nick-
I went through the same thing with my G1. I finally changed all four corners at about 210k miles because I had bought the parts years before and got tired of them being in the way. I noticed a slight improvement, but not a tremendous amount....
awelliott is offline
Old 02-01-07, 09:25 PM   #4 (permalink)
T The pimp
truonghthe's Avatar
Car 2: 93 Legend L AT
Car 3: 92Legend L AT R.I.P
Ok simple just drive your car in a bumby road if you car start to bumb alot and make some noise then Its the time to replace them or you can check leaking on the shock. The best place to test it is in NYC FDR drive you drive at 60-70mph during a curve then I bet some how you will hit a bumb your car shouldn't be throw to the right if you take the left lane. My bro did change his rear shock and change all of the rear sway bar bushing. The car handle soilid now he need to replace the front one also.
truonghthe is offline
Old 02-02-07, 03:22 AM   #5 (permalink)
ReGisTurd uSeR (heh heh)
TheBlindMan's Avatar
Car 1: '92 LS Coupe
Car 2: '95 Mercury Villager
I've got 111,XXX miles on the original suspension. Aside from an occasional knock from the rear passenger side they're golden.
'92 Seattle Silver LS Coupe
Katskinz Leather
17" Acura TL rims
Stock CAI mod
Eibachs over KYB-GR2
Telions Velvet II ECU
TheBlindMan is offline
Old 02-02-07, 06:13 AM   #6 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
You replace a strut after determining that it is leaking/seeping. It will continue to lose fluid until it no longer functions. Symptoms include excessive jounce (up/down movement of front sheetmetal when pressure applied) or uneven tire wear. As a rule-of-thumb, OEM struts typically last between 100 - 150,000 miles depending upon driving conditions. There are of course, exceptions.
As to springs, although they tend to sag minimally over time, you can usually reuse unless you have been habitually been hauling next to max cargo capacity which will tend to increase the amt. of sag over time.
In over 30 yrs of driving, I have only had to deal with a spring once -- a front coil broke, and this was on a GM car.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 02-02-07, 11:46 AM   #7 (permalink)
Stu
Grand Tourisimo
Car 1: Legend
thanks,
-nick-
from your description, you dont need shocks. Is probably a smaller, cheaper part(S) thats dried up, broken or cracked under the car. The weight of the car man, Legends are FAT !
MLS Copy Strut Tower Bar Group Buy is on again !
http://www.acura-legend.com/vbulleti...up-buy-128195/
Stu is offline
Old 02-02-07, 01:14 PM   #8 (permalink)
Car 1: 1991 Coupe-L 5-speed
Honda uses good shocks.
For many Toyota I owned, the shocks lasted for 3-4 years.
Don't who make shock/shuts for Honda... they last forever!!!
BTW, you might noticed the rear is a bit lower then the front (measure from the ground). That means the rear coils are sagging and getting weak. Some people replaced them because of that. My 91 couple tail is a bit lower than the front now, but I am not replacing them if the shock are still good.
91 Coupe-L 5-speed
TatNg is offline
G2 Shocks & Springs at 70K?? RobL Second Generation Legend (1991-1995) 2 05-05-04 10:23 AM
how long do stock shocks & springs last ? Stu Second Generation Legend (1991-1995) 1 08-07-03 11:22 AM
Trade GC/Koni for Stock shocks and springs imaginasian vboy OEM Parts 8 04-10-03 01:02 AM
my rear suspension is sagging a tiny bit! is it due to weak springs or shocks? 91LegendCoupe Second Generation Legend (1991-1995) 34 09-03-02 10:07 PM
shocks and springs? G2-GS Second Generation Legend (1991-1995) 4 07-16-02 02:40 PM
