Springs and shocks, When to replace?
I'm not sure, but is there any certain time when you replace the shocks and springs? As of now I have close to 170K and the car seems to drive fine, no excessice bouncing after hitting bumps or anything like that. I'm sure the stock ones aren't as stiff as they used to be, any input?
thanks, -nick-
New pictures of my 93' LS sedan WTB: Type F, Drivers door weather stripping! PM me! FS: OEM 15in Legend Wheels. Great condition! PM me! |
Chicken & Dumplins
when they break, sang or when you fell like. Mine leaked before they got changed.
Click for Deep Discounts http://4450488.shopwize.com FS/Trade: JDM KA7 Headlights & Door Switch, heated seat switch 91-95 Sedan fender,3.5 RL HEADS , INTAKE MANIFOLD & FUEL RAILS , http://www.acura-legend.com/vbulleti...htside-124468/ http://www.acura-legend.com/vbulleti...ad.php?t=95844 |
#3 (permalink) | |
T The pimp
Ok simple just drive your car in a bumby road if you car start to bumb alot and make some noise then Its the time to replace them or you can check leaking on the shock. The best place to test it is in NYC FDR drive you drive at 60-70mph during a curve then I bet some how you will hit a bumb your car shouldn't be throw to the right if you take the left lane. My bro did change his rear shock and change all of the rear sway bar bushing. The car handle soilid now he need to replace the front one also.
ReGisTurd uSeR (heh heh)
I've got 111,XXX miles on the original suspension. Aside from an occasional knock from the rear passenger side they're golden.
'92 Seattle Silver LS Coupe Katskinz Leather
17" Acura TL rims Stock CAI mod Eibachs over KYB-GR2 Telions Velvet II ECU ![]() |
You replace a strut after determining that it is leaking/seeping. It will continue to lose fluid until it no longer functions. Symptoms include excessive jounce (up/down movement of front sheetmetal when pressure applied) or uneven tire wear. As a rule-of-thumb, OEM struts typically last between 100 - 150,000 miles depending upon driving conditions. There are of course, exceptions.
As to springs, although they tend to sag minimally over time, you can usually reuse unless you have been habitually been hauling next to max cargo capacity which will tend to increase the amt. of sag over time. In over 30 yrs of driving, I have only had to deal with a spring once -- a front coil broke, and this was on a GM car.
#7 (permalink) | |
Grand Tourisimo
Honda uses good shocks.
For many Toyota I owned, the shocks lasted for 3-4 years. Don't who make shock/shuts for Honda... they last forever!!! BTW, you might noticed the rear is a bit lower then the front (measure from the ground). That means the rear coils are sagging and getting weak. Some people replaced them because of that. My 91 couple tail is a bit lower than the front now, but I am not replacing them if the shock are still good.
91 Coupe-L 5-speed |
| G2 Shocks & Springs at 70K?? | RobL | Second Generation Legend (1991-1995) | 2 | 05-05-04 10:23 AM |
| how long do stock shocks & springs last ? | Stu | Second Generation Legend (1991-1995) | 1 | 08-07-03 11:22 AM |
| Trade GC/Koni for Stock shocks and springs | imaginasian vboy | OEM Parts | 8 | 04-10-03 01:02 AM |
| my rear suspension is sagging a tiny bit! is it due to weak springs or shocks? | 91LegendCoupe | Second Generation Legend (1991-1995) | 34 | 09-03-02 10:07 PM |
| shocks and springs? | G2-GS | Second Generation Legend (1991-1995) | 4 | 07-16-02 02:40 PM |
