werd.....
Squeaking lower A arms in front
Is there anything that can be done when the bushings start squeaking on my lower A arms (the massive ones) Can i replace the bushings by themselves or do I need to buy whole new A arms? Stuff like this makes me want to go find poly parts...
Rangerjoe - how do you know it's the bushings on the lower A arms?
As the weather gets colder, my front end squeaks when I go over bumps. I always assumed it was the control arm (sway bar) bushings because it's worse when I go over speed bumps & the sway bar twists in both bushings (left & right). Greasing these bushings is pretty easy to do with silicone grease. It seems to help for a while but only seems to last for 1 year. I greased them last fall & they'r starting to squeak again. Maybe it's not the sway bar bushings on my car that are squeaking. |
I wasn't thinking about the sway bar bolts. There are 2 rubber sway bar bushings. There is a page in the Helms Manual & a DIY on this forum about how to grease them. Pretty easy but questionable how effective it is.
B anned (SIKE!!!)
Can this be done while installing new shocks and springs???? I thought it was my shocks or springs doing that so I got some new ones. Damn, dont scare me....
Check out my new wheels..... http://www.acura-legend.com/vbulleti...9/#post1243334 |
Swollen Member
Phil, I had this problem on the '92 Sedan and the bushings on the right upper control arm had dried out. I bought a spray can of CRC Penetrating Power Lube, soaked every bushing on that side I could get to and I haven't had a problem since. This was after I puked out $263 for a new LCA because I thought those bushings were shot and it turns out a $4.99 can of lube fixes the problem. Gah!
#8 (permalink) | |
werd.....
Swollen Member
Under braking, small to moderate bumps, sharp right hand turns. Got it at O'Reilly.
Yo pedo en su dirección.
nice - my front is squeakin a LOT on my driver's side, and a little on my passenger side. It happens whenever I go over speed bumps or change direction (up a hill, down a hill, or turn).
Even while parked, if I turn the wheel I get the squeak on the driver's side. Think they have that CRC Penetrating Lube at Autozone?
1995 Acura Legend LS Coupe 6 speed NSX seats - JDM Headlights - OEM Fogs - MLS Copy strut bar - Legend specific Tie bars - Addco F&R Sways - KSport suspension - Sr5Guy Stage 2 Chip - RangerJoe Short shifter - Aluminum Pulleys - Injen intake - Stromung 2.5 inch cat-back - S2000 Battery Coming soon to a theater near you... 2005 RL BBK - Upgraded Final drive and LSD - Custom header - Cams - adjustable ball joints - adjustable end links |
#15 (permalink) |
maybe I should just replace it all! 200k miles is a long life already.
| Put new front upper and lower control arms | 9legand1sed | Second Generation Legend (1991-1995) | 0 | 05-07-07 11:09 AM |
| WTB: Rear Lower Control Arms | NoRegrets | OEM Parts | 0 | 09-17-06 12:26 AM |
| WTB: Rear Lower Control Arms | NoRegrets | Parting Out | 0 | 09-17-06 12:24 AM |
| Squeaking Front end. | CoyoteCoupe91 | Second Generation Legend (1991-1995) | 30 | 10-07-05 01:37 AM |
| Rear lower control arms. Are they the same for 91-95's, 2dr and 4dr? | Bemtje | Second Generation Legend (1991-1995) | 6 | 09-29-05 03:28 PM |
