Old 04-04-07, 02:23 PM   #1 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
Car 1: 95 LS Coupe 6spd
Car 2: 94 L Cpe 6spd - sold
Car 3: 98 Prelude - sold
TROUBLESHOOTING BASIC STEERING AND SUSPENSION PROBLEMS
Most problems in the front end and steering are caused by improperly maintained tires which you can correct yourself, or by incorrect wheel alignment, which requires the services of a professional mechanic. Get in the habit of checking tires frequently; this is usually the first place that problems in the front end or steering will show up.
Hard Steering (steering wheel is hard to turn)
Code:
Is Caused By What to Do Low or uneven tire pressure Inflate tires to correct pressure Loose power steering pump drive belt Adjust belt Low or incorrect power steering fluid Add fluid as necessary Incorrect front end alignment Have front alignment checked/adjusted Defective power steering pump Have pump checked/repaired Bent or poorly lubricated front end parts Lubricate and/or have defective parts replaced
Loose Steering (too much play in the steering wheel
Code:
Is Caused By What to Do Loose wheel bearings Adjust wheel bearings Loose or worn steering linkage Have worn parts serviced Faulty shocks Replace shocks Worn ball joints Have ball joints checked /serviced
Car Veers or Wanders (car pulls to one side with hands off the steering wheel)
Code:
Is Caused By What to Do Incorrect tire pressure Inflate tires to correct pressure Improper front end., alignment Have front alignment checked/adjusted Loose wheel bearings Adjust wheel bearings Loose or bent front end components Have worn components checked/serviced Faulty shocks Replace shocks
Wheel oscillation or vibration transmitted through steering wheel
Code:
Is Caused By What to Do Improper tire pressures Inflate tires to correct pressure Tires out of balance Have tires balanced Loose wheel bearings Adjust wheel bearings Improper front end alignment Have front alignment checked/adjusted Worn or bent front end components Have front end checked/serviced
Uneven tire wear
Code:
Is Caused By What to Do Incorrect tire pressure Inflate tires to correct pressure Front end out of alignment Have front alignment checked/adjusted Tires out of balance Have tires balanced
Mods may want to sticky this.
Someone stole maracura91's new wheels one day after he bought them. (10/09/2008)
This link will search for "Nitto" + "C2" + "Racing Hart" on all of craigslist for the last 24 hours. Click it to help him find his wheels!
maracura91's thread
Inflation is your friend! I mean really, who doesn't want to own a $100,000 car?
kotetu is offline
Old 04-04-07, 02:33 PM   #2 (permalink)
VIP Well Wisher
GrtOutdoorsAZ's Avatar
Car 1: '94 GS sedan 6MT
Car 2: '91 L sedan 4AT
question for you tire guys...I'll admit, I feel a little silly asking:
I have 215/45/17's on my '94. When you look at the tire wall, it says 45 MAX PSI...
I got my oil changed at Jiffy Lube the other day (I was in a pinch, needed it done quickly - otherwise, I'd do it myself)...and part of their service is to check the tire pressure. When I looked at the receipt later, it showed that the tires had been set to 35 PSI.
do cars have a general tire pressure range that they're supposed to be in (hence Jiffy Lube putting it at 35), or is the tire pressure always specific to the exact tire? should my tires be at 45? I get that depending on situations, you may want to raise or lower your pressure....but for everyday driving (almost all highway)...what should my pressure be set at?
I am super anal about suspension / tire stuff...I get them balanced and rotated every other oil change. I always take my car in as soon as I feel any weird vibrations, etc...in the last month, I've replaced both front axles on both my Legends. I just filled up for $3.28 / gallon (THAT'S NOT A TYPO) and anything that would take away from my gas mileage is a big no-no.
'94 GS 6MT
Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs
Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires
Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather
GrtOutdoorsAZ is offline
Old 04-04-07, 03:22 PM   #3 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
here's the link to tirerack's tech site: http://www.tirerack.com/tires/tiretech/tiretech.jsp I always inflate my tires to the max pressure listed on the tire itself, and I try to always do it in the morning before I drive.
maracura91's thread
kotetu is offline
Coilover, Shocks, Struts, & Springs by B+O + Official suspension guide by Swift B+O Wheels, Tires, Brakes, and Suspension 41 12-12-06 11:22 PM
Steering out of whack after minor accident nightspd First Generation Legend (1986-1990) 6 07-19-06 12:37 AM
HELP!!! Weird Steering Problem charlesb2003 Second Generation Legend (1991-1995) 7 08-01-04 11:44 PM
