Old 02-10-08, 02:27 PM   #16 (permalink)
I'd shit on you for free.
BUSINESSMAN07's Avatar
yes wider tires = more surface area+water= more displacement of water + speed= hydroplane.
Now take a donut rolling through a puddle. notice howmuch water is displaced.
then take a 225 tire and roll it. notice how it slows down considerably to displace all that water.
multiply by 5 and you have hydroplane.
end/
Originally Posted by DandDEE View Post
you should teach her to make u some eggs like "bitch make me some eggs" ...
Originally Posted by Perfect A-L Member View Post
Dude just drop it...If your not gonna contribute then get the F*ck out of this thread..I hope you crash and no one helps you out. Then you'll know how it feels..Are you just mad that no one likes you enough to help you out? Alex isn't asking for money..we are offering it..that is what this community does for each other...
Tha Fuck crawled up his vagina and died?
BUSINESSMAN07 is offline
Old 02-10-08, 04:49 PM   #17 (permalink)
B+O
G2BMC
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
i feel like i just read and re read the same theory multiple times by many multiple people
but atleast believe its been solved
unless you guys want me to call up my buddy at tire pros.. get some more opinions
Same theory over and over again. That same theory is assuming that EVERY single tire has NO tread on it. The more tread grooves the less surface area, which reduces that theory's effectiveness simply because a wider tire with more tread blocks in it will have less surface area than a skinny tire with absolutely no tread blocks.
It comes down to a lot of factors, and no...just be cause it's wider doesn't mean it will hydroplane easier.
And misdiesmo your take on the theory with that Pen and the Wooden board is off as well. The pen's Density is what caused it to sink, no so much its surface area. a Ball point pen's density, or its Mass over its Volume is higher than the density of the water. Wood is actually less dense than water...well most woods are, and that's why it would float.
and Murderotica....the more open area there is inside of a sea-faring vehicle, the less its density is, relative to water. The whole "surface tension" is a factor, but more so the ability to float on something is the ability to have a less dense accumulation of parts. This is why water is down, and why air is up. Air is less dense than water. The more "surface area" you have between vertical partitions, the less dense that vehicle becomes. The less dent it is, the easier it is to float.
Surface tension is really only referenced in Ballistic analysis when describing water in itself. Unless the surface tension of a puddle is enough to withstand hundreds of thousands of pounds in force (relative to a car moving forward and the gravitational forces pushing the car down) then i don't believe it's SOLELY based on surface tension.
Again, if the tire was without tread blocks, this all would be different. but the blanket statement that a "wider tire hydroplanes faster" is pretty misleading. It's more about the ability of the tire to displace water versus its buoyancy.
Originally Posted by Michelin
A rain tyre is capable of dispersing tens of litres of water in the space of one second. Because track surfaces tend to be cooler in the damp, this kind of tyre has to be able to operate at much lower temperatures than its dry-weather counterpart - usually 30°C to 50°C. It has a slightly broader diameter than a dry tyre, in order to help increase ground clearance
Originally Posted by Bridgestone
Whilst the wet tyre is capable of displacing in the region of 34 litres per second per car, the extreme wet can displace almost double this at 61 litres per second, with these figures dependant on the speed travelled and amount of water on the track.
EDIT:
Idon't know about you, but those tires sure don't look skinny to me.
B+O is offline
Old 02-10-08, 04:59 PM   #18 (permalink)
misdeismo's Avatar
true true but i just used wood as an example of something flat. probably not the best example but the point is pounds per square inch. with respect to tread, one would have to calculate the absolute area in contact with the water to determine whether it is more prone to hydroplane than a narrower tire.
misdeismo is offline
Old 02-10-08, 06:29 PM   #19 (permalink)
Artillery129's Avatar
Car 1: 95 Acura Legend
i think one would have to calculate an average of water contact per area of a tire at varying speeds because the efficiency of the treads Is probably not linear
Originally Posted by Boondock Saint View Post
change your user name to: Pimpmyride. why your ask? because you always put the most random shit in your car.
Originally Posted by redac93 View Post
WOW!!!!SO WHAT NEXT A POPCORN MAKER IN THE TRUNK
Chromed Grill, Seven X Wheels, Clear Corners, Spoiler, Custom Bumper, Exhaust tips (Woo Woo!) Fog Lights, Garage Door Opener Mod, Repainted Head Unit, Fog Machine, Short Ram K&N, UnderCarriage Lights, Sylvania SilverLights Headlights
Artillery129 is offline
Old 02-10-08, 07:34 PM   #20 (permalink)
***s=reliability.I swear!
FF Drifter's Avatar
Your F1 picture brings up a whole host of new questions Ivan LOL
All along we've been talking about PSI, but F1 cars are incredibly light. Can we assume that a heavier car like our Legends get away with wider tires because it's weight keeps the rubber in contact with the road? This is the whole reason FWDs are generally considered better off in adverse conditions than RWDs right?
FF Drifter is offline
Old 02-11-08, 01:22 AM   #21 (permalink)
B+O
G2BMC
B+O's Avatar
Car 1: why?
very complicated question you pose there. I'll try not to tangent of the given subject too much. And i'll touch on the drive wheels point as well.
At lower speeds F1 cars are incredibly light and as such rely heavily on their tires for grip...especially in corners. At speed however they rely on downforce. the downforce effectively multiplies the force the tires have to break away water forces. That said, street cars themselves have a large amount of weight so the force acting on the tire is more Gravity and Mass than artificial mass of "downforce" as downforce is just artificial "weight" added to the car.
So in essence, yes the Legend and other street cars rely on weight to effectively keep tires on the pavement. The legend in specific has a generous weight envelop and would have substantial gripping potential (not as high as a W140 Mercedes but you get the idea). So it's less likely to hydroplane on any tire it uses as compared to say a Civic or a something lighter.
That all said, it is imperative that as the weight starts going up, you have more rubber on the road, especially in wet conditions. This is why I made the point earlier that if a thin tire was the answer to hydroplaning we'd all be skating on Wagon wheels. The thinner the tire, the more traction is required out of a smaller area. this gets increasingly complicated when you add to the problem with a slick surface. This is why F1s use are large tire in the rain, traction isn't based on a tire's buoyancy. It's based on its performance.
I looked up the Tires you're running Fred. The Ecsta SPT bears a stricking resemblance to the Hankook RS2.
The RS2 and the SPT are both something like the Perelli Asimmetrico
one of my Favorite tires (aside from the RE540S and A048).
The Asimmetrico Was an awesome dry weather tire but its tread design was outclassed when it came to wet weather traction. the problem is that only a portion of the Tread was devoted water evacuation. If you look at the tire's tread pattern, there's unbroken treads bands. These are pretty useless when it comes to wet traction, but in the dry it helps regulate and stabilize the tire's temperature. Also the parts that are dedicated to dispersion are pretty blocky. They're not smooth at all and this builds hydraulic pressure effectively stopping flow.
Moving on to the RS2 from Hankook...
The Hankook is my new favorite Attainable tire (Still have a crush on the now discontinued 540S and the Asimmetrico but they're hard to find). this tire is amazing in the dry, but its wet traction is, at best, mediocre. Problem with this tire is the same as the asimmetrico. The solid tread blocks are non beneficial to evacuation of water. and the tread that is available for evacuation doesn't really push the water out from under the tire. it kinda just moves it over a bit allows the tires to sink a bit more into the water.
Now to the SPT...
Now they said they used a new tread compound to "improve" wet traction. You know...that's all well and good but there's just one thing. The tire can have newly chewed bubble gum for a tread compound, but if it can't reach the road, it's all for naught. here we have the same problem. The tread isn't designed with water evacuation in mind. Looking at it, there is a better tread design for wet weather than the RS2, but not much...This is the root of your hydroplaning problems.
Now as far as the Drive wheels. The drive wheels in this particular instance (inclement weather) play a big role in stability more so than traction. given 50/50 weight distribution for a front drive and a rear drive of equal weight, the front drive car will have superior performance. The reason is that in basic kinematics, it's more efficient to pull a mass than it is too push a mass. when pushing a mass, energy tries to escape. it will go to the easiest path, and to the side is always easier than pushing forward (this is what you'd call dog trotting) a common occurrence in big tire smoking, showboating antics with RWD cars. With a front drive vehicle, the energy has no where else to go but where it's directed. there's no chance for it to move to the side to bypass the system.
In essence think of pushing a log up a hill. when pushing that log up the hill. the front will want to move around and not go exactly straight up the hill. so you'll have to walk sideways to keep the front end going up that hill. now take that same log and drag it up the same hill with when pulling it up the hill from the front of it, the energy is coming from the front. everything in the system behind the energy has to follow it. It's only been since the affordable implementation of traction control, stability assist, fuzzy logic transmission controllers and ABS, has RWD become a desired drivetrain again. RWD is an inherently unstable platform and the need for lots of electronics and safeguards need to be implemented, especially on higher HP platforms.
What is a good tire design???
Well there's a few...
The KDW is one.
Though not the prettiest tire, it's design is very functional. The WIIIIDE siphons that trail a LONG ways up the tread going straight out the shoulders allows for maximum evacuation of water from under the tire. The lack of extraneous groves allows the maximum amount rubber to still be planted for the best grip.
Yokohama AVS Sport
This was, and is a VERY good tire. its design is straight forward, simple and strong. The tire was good in both the wet and dry, but it could have used a softer compound. It was pretty sticky and fun to use, but excellent in the wet and dry.
Goodyear F1 GSD-3
This is a GREEEAAAT tire for the rain. The design of the tire is specifically optimized to reduce hydroplaning at high speeds. the large amout of openspace however compromises the effective contact patch, but dry handling is still crazy because of the advanced compound it uses. This tire is a really good tire.
B+O is offline
Old 02-11-08, 07:50 PM   #22 (permalink)
So smooth, so TAN, mmmmm
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
Plus, our engines weigh a considerable amount more than our trunks with the CD changer back there, so, there in quite a bit more PSI on the front tires than the rear tires!
DUAL REMUS IS PHOTOSHOP!
http://www.acura-legend.com/vbulletin/883766-post7.html
91 with type II engine, SR5GUY stage 3, hi flow cat, 6 speed tranny, 04 TL knob, EDM headlights, EDM spoiler, carbon fiber interior trim, type II cluster, OBX headers, 2 1/2" Catback to Remus Rev 3, CAI.
blkonblkcpe is offline
Chocolate Rain - 56k must settle for Regular Rain. Double Glow The Lounge 23 10-06-07 07:23 PM
What is 2" wider than P205 60R-15's ?? Josh Second Generation Legend (1991-1995) 10 11-04-06 12:11 AM
Wider is better kostas86 The Lounge 24 10-06-06 01:42 AM
makem a little wider benzacura First Generation RL (1996-2004) 2 07-24-06 12:47 AM
wider tire width on GS rims? sclegend Second Generation Legend (1991-1995) 5 12-16-05 11:03 PM
