[img=http://img295.echo.cx/img295/3343/a41b9yx.th.jpg] You guys know the difficulty level in putting this in ? not bad for 48 dollars huh ...
Dont you just remove the center console?Thai.95LCoupe said:You have to remove the radio. There are 2 screws holding the A/C unit in. Then do the screw driver method.
There are definitely 2 screws behind the radio that hold it.jackdanielsman said:Dont you just remove the center console?
