I have gift for you guys, in 2 weeks, i'm sending my 1993 sedan with gs type 2 motor, to the guys in arizona and i'm going to get a turbo kit
i'll keep you guys posted, thanks
This is why it's crucial to have proper engine management. I know in most cases lean is what we want; but, while Kyle's testing higher boost and trying to reach his goal of 300WHP he's gonna have to run as RICH as possible with the least advance possible. That's just how it's gonna have to happen at first, otherwise yes the bottom end will bust. He's running around 5.8psi right now, and he's probably gonna have to run at 10psi to see 280-300whp who knows exactly how much it will take to get a solid 300. Boosting around 10psi, that's around what most other Hondas can safely take and it's not really that extreme but in our semi high compression engine it's definately enough on a stock bottom end. I can't predict the future but if Kyle gets the proper management I know the final number will be impressive but how impressive is the question.LS92Sedan said:I dunno, I think the rods will handle some power, but I fear that the stock cast pistons will warp or crack under the heat of turbocharging, I can set you up with a company that sold me some custom pistons, I have yet to install them but the quality looks fantastic compared to the stock pistons.
autotronics i believe... he's also dealer for themShaylord said:buzzard uses something other than the aem I cant recall what it is off the top of my head, i just remember it wasnt the aem, does anyone know of a good tunning shop in new england say boston ma or manchester nh area?
bingo, you're right! I forgot which one it was, thanks.badintentions said:autotronics i believe... he's also dealer for them
Actually the NSX base tune is very similar to ours. Read the thread about chipping the stock ECU's; the Bayou chip is based on the NSX ECU not ours.LS92Sedan said:I doubt that we are going to be able to use the NSX base map as a pre cursor, its lookin like we are going to have to base tune ourselves, unless there is some way to take the stock ECU base and program it to the AEM, the NSX base tune is miles away from our base tune. Unless of course we find some way to piggy back the ECU via like an emanage or something, I would suggest using a cheaper stand alone before jumping into the AEM. Just my $.02.
Yeah, don't get me wrong it's definatley not the tune you'd use, but I know now they have enough similarities that it would make tuning easier. I mean whoever that was that had to retune everything, wouldn't you rather retune than tune from scratch? Maybe it was just him; I dunno we'll see soon. As far as the Bayou tune, that's probably exactly why it runs rich. Beav the guy who has been studying the .BIN files for the bayou said it's nothing more than the NSX map changed around in a few places to compensate the Legend.LS92Sedan said:the guy that used the NSX AEM standalone on his Legend had to basically retune everything, the base was day vs night, maybe that was just one person, we'll have to see what happens. As far as the Bayou tune, alot of Bayou users say the Bayou chip runs pretty rich, and if it is based off the NSX that would explain why, I think the Bayou chip is one that needs a cam and port work in order to run efficiently.
Reason why the AEM looks so attractive is because of the NSX AEM EMS. It's a dead ringer for the same ECU,harness, and connectors as a Legend. There are different wires going to different places but thats not nearly as much of a problem. As Imran pointed out in his AEM EMS Legend thread and much follow up research ive been doing, the NSX base map should get the car up and bearly running once a few wires are addressed. With an experienced tuner on a dyno that should cut tuning time and save money Vs. a from scratch system.badboyr66 said:My 2 cents
Why anyone would go with AEM is beyond me. There are many and cheaper kits out there. I personaly like SDS... have used on many cars with no issues. As far as turbo location there is the remote mount option. STS came by the shop with a demo truck and I have to admit... when I saw the setup I was like.. "Whos back yard idea was that?" After a ride and seen the truck on the rack... it worked out very well.
http://www.ststurbo.com/
I am looking into a system for my car
Will these pose a problem on a Legend Engine?badboyr66 said:
Nothing to learn. You just index the crank pulley and install a magnetDv8 said:Will these pose a problem on a Legend Engine?
# SDS is not compatible with OE crank sensor systems.
# Not compatible with OE air idle control systems.
I dont want to learn how to figure it all out, i want a tuner to do that on a dyno. Is that bad of me??
U do enough for the community, if someone can help you and make everything you done easier, god bless them lol, said it be4 ill say it again ur my hero/ inspiration man much respectDv8 said:I dont want to learn how to figure it all out, i want a tuner to do that on a dyno. Is that bad of me??
Well thanks man! Makes me feel good.Shaylord said:U do enough for the community, if someone can help you and make everything you done easier, god bless them lol, said it be4 ill say it again ur my hero/ inspiration man much respect
~Shay
