You don't see these jewels all the same place too often. Just thought I'd share.
I better not get banned or flagged for this, because you asked. This is where I work...where might that be?
Right!?! I don't know why everyone is stuck on trying to put the NSX engine in a G1 Legend, when the TL-S is set up almost exactly like the Legend, and fabrication for fitting the motor and trans would be a LOT less!Ironic how that TL-S has almost the same power as the NSX, in a four-door sedan.
i thought about that and wondered if it was possible and is the engine in the TL north south positioned like the g2???Right!?! I don't know why everyone is stuck on trying to put the NSX engine in a G1 Legend, when the TL-S is set up almost exactly like the Legend, and fabrication for fitting the motor and trans would be a LOT less!
