1 - 19 of 19 Posts
Discussion Starter #1
hi guys, i have some 18s on my legend right now i have a set of 20s on 225/30/20 that im thinking about putting on it. well what i want to know is will i have any problems with them.
Moderator
I have 20's and they are fine unless I hit real hard bump. I suggest getting fenders rolled, offset plays a big part in how wheels fit.
Fut RIP
Same here and I don't have the bump rub as my boy big boi dose and as he said offset will play a big part in it as well as how wide they are
Fut RIP
Fut RIP
from what ive seen on KA7 legends so far is
18x8.5 with +30 off set on the front with (205/40/18's) and 18x10 with +25 off set on back with (215/45/18) on rear.
18x8 with +49 off set on front with (215/35/18) and 18x9 with a +37 offset on rear with (225/40/18)
18x8 with + 47 on front with (215/40/18) and 18x9 with +47 on rear with (225/40/18)
18x8 with +47 on front with (225/40/18) and 18x8 with +42 on rear with (225/40/18) now these are all on dropped ka7's and most are tucked!
Fut RIP
this ive seen on ka9's so far.
19x8.5 with + 35 on front with (225/35/19) and 19x9.5 on rear with +40 with (235/35/19)
19x8.5 with + 35 on front with (215/35/19) and 19x10 on rear with +44 with (245/35/19)
20x9.5 with + 38 on front with (225/35/20) and 20x9.5 on rear with +38 with (225/35/20)
19x8.5 with +37 on front with (215/35/19) and 19x8.5 on rear with +28 with (215/35/19)
19x8.5 with +37 on front with (225/35/19) and 19x9.5 on rear with +38 with (235/35/19)
20x10 with +33 on front with (225/35/20) and 20x11.5 on rear with +36 with (255/35/20)
now these are all tucked!
Fut RIP
20x8.5 with +34 offset with 225/35/20 on front and back. Same set up with 225/30/20 as well.
I have a really big question. I just bought a 93 legend, some goofball has it sitting on 245/35x20 on a 8.5" offset of +40, there is an obvious rubbing issue and I cant afford new rims or can find stocks rims in my area. Can I go to a 225/30x20? The tire shops say its to heavy.PLEASE HELP
Fut RIP
yes you can 225/35/20 will work also. try a junk yard for factory rims
A Question.
I currently have a set of 18"x8 TSW Mondello rims that are being tested on an Acura RL with Kumho Ecsta Supra 712 225/40Z/R18 tires.
Initial stress tests show the right side suspensions are gone, front more than rear, but both couldn't even handle a 90lb passenger (our more extreme test had a 200+lb passenger in front and 170lb passenger in back on same side). Driver side seemed fine, even under quick right-turn scenarios. All spirited left turns return with grind, grind, grind so we are replacing right struts.
Based on these wheel specs, are there any concerns we need to be worried about? Such as rubbing or fender rolling?
Thank you in advance.
Edit: I should note the Acura RL is the first generation KA9.
You should check 4WheelOnline. That's were I got my 18" wheels when I've decided to upgrade from 16 to 18. They have a good selection of chrome and alloy, but I can't say which brand would be best suited for you.
1 - 19 of 19 Posts
