hey yall... will try 18x8 with a 40" offset?.....can you mount a 225 on that without rub?....
L LEGEND · Registered Joined Jan 25, 2002 · 163 Posts Discussion Starter • #1 • Feb 7, 2002 hey yall... will try 18x8 with a 40" offset?.....can you mount a 225 on that without rub?....
D Dave C ver2.0 · *r**h *eller Joined Jan 17, 2002 · 1,920 Posts #2 • Feb 7, 2002 Not a snowballs chance in he!!.
A aiznpride · Registered Joined Jan 17, 2002 · 1,453 Posts #3 • Feb 8, 2002 18x8 with a +40 mm offset? even if you get thinner tires, the rim itself will probably run. =)
CakeDaddy · Banned Joined Jan 28, 2002 · 2,261 Posts #4 • Feb 8, 2002 18.7.5 w/225 40's may be your best bet.
A acuralegend.com · Registered Joined Jan 17, 2002 · 1,913 Posts #5 • Feb 9, 2002 CakeDaddy said: 18.7.5 w/225 40's may be your best bet. Click to expand... ..and only if you didnt lower the car.
