1 - 9 of 9 Posts
because i can.
It was originally Type E leather, you can see from the door inserts...they just replaced the seats with cloth ones probably from a junk yard...
This seller is full of shit...he says it was pampered yet it has replacement cloth seats, a cracked windsheild, a leaking valve cover, and malfunctioning tach and cruise....I'd give him $800-$1000 at most....:thumbsdow
because i can.
I just sent this question to the seller:
Hello,
Why does the car have cloth seats but leather door inserts? Does it tick when started in the morning? When was the timing belt and water pump last changed? How are the suspension components? Any creaking or noises? Does the air conditioning work? When was the cooling system last serviced? Do both cooling fans work? Has the PGM-FI light ever come one before? If so, what was the problem?
Thank you.
1 - 9 of 9 Posts
