1990 Legend 4 dr, 6 cyl, auto trans, 248K miles.
The transmission started shifting from 1st gear straight into 4th gear around 3500 to 4000 rpm.
Thanks to this forum, I was able to remove the solenoids from the tranny and clean them. The problem went away for about six to seven months.
Now the same problem has started again.
A few questions please:
*Will changing the fluid two or three times to flush the system help the transmission.
*After changing the fluid several times (assuming I do), I would prefer to replace the solenoids rather than cleaning them again. Does anyone know a reasonable source where I could order new solenoids? My local dealer wants $198 per solenoid bank. ($400 total)
*Where is the TCU unit? Is the error code light on the front or rear of the TCU?
Any advise would be welcome. The body of the car and the interior is in excellent condition however I would not want to spend the money for a tranny rebuild.
Thanks again for the help.
DT
DT
