This car has had problems with overheating off and on for about two years. There are no signs of coolant on the ground or on the engine areas. The last time it was in the shop for this they checked the following: Oil in coolant (none), pressure in cylinders (ok), and pressured the coolant system (ok). They add some conditioner to the coolant system just incase there may be a small leak. Then my son last night was driving back from LA to SF and the car start to overheat while stuck in traffic on Highway 5. He noticed the the temp gauge was climbing and some white smoke was coming out of the exhaust. The heater was also going from hot to cold. He pulled over waited a while then checked the coolant levels. He noticed that the reserve was full but the radiator was a pint or more down. He filled the car up and continued home. The car seemed to be okay. This morning I noticed when idling the car for 5 or more minutes that the lower radiator hose did not get hot? Maybe the thermasat is not opening? The heater did get hot? So how long should it take for the thermasat to open? Also what would be the best way to determine if the head gasket is blown, and which head?
Any thoughts?
Merr Christmas to all
Any thoughts?
