I agree with Matt. I had an 88 Prelude where there was never stop-leak put in (I was second owner and it never had any cooling system problems and I bought it with a broken timing belt). When I had the head off, everything was spotless after running with the OEM coolant. I opted not to change the water pump as it was original and functioning perfectly after 6 years and 140k miles.
Two years went by and I decided to replace the water pump before a trip just for security. I replaced it with an OEM pump (because the first one lasted so long) and put in nice, fresh Prestone. Three years and about 40k miles later, the water pump started leaking from the bearing seals. When I replaced the pump, there was that same gooey stuff in there that Matt found.
NOW, I have my Legend. Water pump was replaced at 139k. Now, at 176k, after having Prestone in it, it's leaking from the bearing seals.
If you go to any radiator shop, they will tell you as well that Prestone uses a small amount of stop-leak compounds in their mix and that's what we see in those pics.
NO MORE PRESTONE FOR ME.
