1 - 2 of 2 Posts
$700 from ASAP motors in Texas and $1080 later with clutch and motor mount and rear main seal and.....
Worse noise than the original tranny- all thru the gears -seems a very common output bearing was spun on both tranny's - even the $700 one from ASAP motors in Texas -Currently I am working on getting the USed tranny back out and shipped back to ASAP -http://www.asapmotors.com/
But the original tranny -170k is getting that bearign replaced now for somewhere between $500 &$700 on top-
Any one else deal with a tranny situation like this?
Prior the car would shift fine, but slip in and out of ashimming noise when applying throttle - "spun bearing---"
see attached photo -
Dave
· 88 sleeper
Dave
wow what are the symptoms of a spun bearing??
is there clicking while under power?
because my recent problem is that the car drives & shifts fine. but while in gear....when i apply throttle; theres a minute clicking sound....every gear. i changed the tranny fluid & still the clicking...the car shift smoother now... what ive been thinking was a synchro or my diff was going out..but im not sure anymore since hearing of this
1 - 2 of 2 Posts
